crane mixing valve
Discussion in 'Shower & Bathtub Forum & Blog' started by sshakkour, Mar 16, 2008.
  1. sshakkour
    sshakkour New Member
    Mar 16, 2008
    greetings
    after looking on the net for the valve i have in the shower i am almost sure i have a crane pre-war mixing valve , and i have a dripping leak ; i did remove the stem and removed the packing nut which was hard to put back because of the spring in it ;but really i do not know what i should be looking for to replace or to stop the leak. please help
    thanks
    sshakkour
  2. jadnashua
    Does the stem have a washer on the end? If so, take the screw out and install a new washer. Then, take a close look at the part where that washer seats...funny thing, it's called the seat. If that isn't smooth, you should replace that. You need a special (inexpensive) tool to remove it. If the stem itself is all worn out, you might be able to find a replacement for it...the easiest way is to take it with you to a good plumbing store. In the end, it might be time to replace the thing with a new valve...over 50-years is a long time...
  4. hj
    valve
    How about a picture. Most valves do not have springs on them, and once you remove the stem there is seldom a need to remove the packing nut.
  5. sshakkour
    Mar 16, 2008
    pictures
    these are the pictures
    [​IMG]
    [​IMG]
    [​IMG]
    hope this will help ; sorry it took me some time to figure out this .
    thanks
    sshakkour
Similar Threads: crane mixing
Shower & Bathtub Forum & Blog Crane Tub Spout Mar 30, 2016
Shower & Bathtub Forum & Blog Crane (OEM) tub tap - H & C tabs - keep popping off! Jan 1, 2012
Shower & Bathtub Forum & Blog 1950s Crane Tub/Shower Problem Jul 20, 2011
Shower & Bathtub Forum & Blog Help finding replacement parts for Crane brand shower stems. Nov 12, 2010
Shower & Bathtub Forum & Blog Crane tup spout won't turn Jul 29, 2010
