Crane Dial Ease Replacing - Bathroom Faucet
Discussion in 'Plumbing Forum, Professional & DIY Advice' started by bbbluueyes, Mar 23, 2006.
  1. bbbluueyes
    bbbluueyes New Member
    Mar 22, 2006
    Hi , I am trying to fix a dripping crane bathroom faucet...I had two dial ease (the #4 on the picture) parts on hand so I thought I would replace both...
    1. I have proper water connections and pressure.
    2. When I replaced the dial ease I could not get any water to go through the spout. I did turn the small dial on top of the dial ease to open and close...
    I am wondering what the heck I am doing wrong....I have done several dial ease bathtub connections before without any problem...
    I obviously installed the dial ease wrong if that is possible?????
    Thank you, any suggestions would help!
    Paul Engstrom
  2. Master Plumber Mark
    Master Plumber Mark Master Plumber
    Feb 6, 2005
    Sensitivity trainer...healey-feeley.....
    dont know
    if you bought 2 new complete brass replacement cartridges--stems
    I dont think its possible to screw it up
    I never have tried to repair the old stems, but
    If you decided to somehow repair those stems with small
    reapir parts, then anything is possible....
  4. bbbluueyes
    Mar 22, 2006
    yes, I bought two new ones...I am wondering if I installed them too deep....
  5. plumber1
    plumber1 Plumber
    Aug 7, 2005
    Florida
    dial ease
    With the stems in an open position or with the stems out try blowing back through the spout and see if you feel a restriction. Put your mouth over the spout and blow.........Take the aerator off first.......
    Otherwise I don't see how you can go wrong. It's pretty cut and dried.
  6. bbbluueyes
    Mar 22, 2006
    thank you, I will give her a try...Paul
  7. hj
    crane
    You can't install the Dial-eze stem too deep, not can you install it any other way to do it improperly. The only thing you could do wrong would be to install it without the stem being in the closed position while installing it, but even that would not cause your problem.
  8. Master Plumber Mark
    Feb 6, 2005
    Clogged Areator
    My guess is just a clogged up areator,
    I have gone out on many service calls
    where this was allthat was wrong
  9. bbbluueyes
    Mar 22, 2006
    it wasnt the aerator, I am going to work on it on Sat...
Similar Threads: Crane Dial
Plumbing Forum, Professional & DIY Advice Angled Crane Dial-Ese faucet mount lavatory sink repair? Feb 20, 2012
Plumbing Forum, Professional & DIY Advice Crane Dial-Ese Drips After Stem Replacement Mar 26, 2006
Plumbing Forum, Professional & DIY Advice Any tips for packing a vintage Crane Mixing Valve Jan 29, 2016
Plumbing Forum, Professional & DIY Advice 36 year old Crane Demming sub pump Oct 27, 2015
Plumbing Forum, Professional & DIY Advice Crane faucets from 1930 - desperate to repair.... Aug 25, 2013
