Crane Bath faucet Leak Question
Discussion in 'Shower & Bathtub Forum & Blog' started by TBB, May 7, 2007.
  1. TBB
    TBB New Member
    May 7, 2007
    We have a Crane Drexel bathtub faucet that leaks from the cold side. I replaced the cartiridge and washer (I also put a new washer on the hot side and it continues to be just fine.) The cold continues to drip, but not as bad as before. As my two-year old says "it's dripperring!" Any suggestions to how to get rid of the drip (drippering)? Thanks...
  2. Verdeboy
    Verdeboy In the Trades
    Jun 12, 2006
    Leaky Faucet
    I did some research and found that some very old models require a double thick washer or stacking 2 washers on top of each other. If that doesn't work, you can try using a fat beveled washer. I'm not sure if there is a seat that can be removed and replaced.
  4. TBB
    TBB New Member
    May 7, 2007
    Thanks You - two washers better than one!
    Thank you for the advice. The two washers did the trick. My two year old daughter is now saying "fixed it, no more dripperring." Given that the tub is tiled, to have to replace would have been teribly burdensome. Thanks again!:)
Similar Threads: Crane Bath
Shower & Bathtub Forum & Blog Need help with crane single-handle bathtub faucet Dec 6, 2008
Shower & Bathtub Forum & Blog remove tub drain for crane bath tub Jan 3, 2005
Shower & Bathtub Forum & Blog Old Crane bathtub stopper - HOW to remove it? Sep 17, 2004
Shower & Bathtub Forum & Blog Crane 2 handle shower valve body too shallow in finished wall surface May 14, 2016
Shower & Bathtub Forum & Blog Crane Tub Spout Mar 30, 2016
