eyas52806
Hi, need some help with my shower. I was replacing the shower arm coming out of the wall with an "S" shaped pipe since the old one was so low it was difficult to take a shower. Unscrewed the pipe (arm) just fine and installing the new one I overtightened to the point I heard a crack and the new arm loosened. I can see the fitting where the arm screws into, which appears plastic (pvc?), has a hairline fracture running along the length of it. The threads look ok. I don't want to put a pipe on there since it will probably leak now. Anyway can I replace that fitting? It's inside the wall maybe 1 cm or so and the opening is maybe a little under 2 inches diameter. Appreciate any help. Thank you.
