Cracked gas regulator on new stove?
Discussion in 'Plumbing Forum, Professional & DIY Advice' started by TedSF, Feb 27, 2013.
  1. TedSF
    TedSF New Member
    Feb 27, 2013
    San Francisco
    Hey there,
    Long time reader, first time poster. Anyways today I was trimming out a kitchen and while tightening a 1/2 male by flare adapter into the stove's regulator I heard a crack, I stopped tightening there and pressurized the line and sure enough the bottom of the pressure regulator had a crack along the female threads. Upon removing the flared adapter I noticed that my pipe dope had only reached about 1/2 way into the fitting and while I was tightening I felt like the adapter was still somewhat loose (I do not believe I was excessively over tightening). Anybody ever seen this? Could the casting on the regulator be faulty? I'm gonna have to swap out the regulator either way (which will be a nightmare) but was just wondering so as to avoid this in the future. I can recall one time that I had a brass 1/2" ball valve crack but never seen or thought it was possible for a regulator. :confused:
  2. jadnashua
    Often, the gas fitting is a flared fitting which doesn't need to be super tight. If it is a tapered thread, then yes, tight shouldn't be a big deal. If it's a flared fitting, it technically, doesn't need any pipe dope, but you could put a little on the flared face - none needed on the threads.
  4. TedSF
    TedSF New Member
    Feb 27, 2013
    San Francisco
    The flared side of the 1/2" MIP by 1/2" flare fitting was not threaded into the regulator, was the normal 1/2" IP male threading into the 1/2" female inlet to the regulator.
  5. kreemoweet
    kreemoweet Member
    Sep 7, 2009
    Seattle. WA
    Regulators usually made of aluminum or some kind of pot metal = soft as hell = don't tighten like you would on steel. Watch out for the chintzy brass
    gas shutoffs too, I've had to repair a few of those that got split by plumbers tightening up a nipple too hard.
Similar Threads: Cracked regulator
Plumbing Forum, Professional & DIY Advice 3 Inch copper waste pipe cracked and leaking. Feb 13, 2017
Plumbing Forum, Professional & DIY Advice Cracked elbow below closet flange Dec 24, 2016
Plumbing Forum, Professional & DIY Advice Cracked drain pipe under shower concrete slab Sep 4, 2015
Plumbing Forum, Professional & DIY Advice I got lead and it cracked a bit. Jun 25, 2014
Plumbing Forum, Professional & DIY Advice uneven slab, cracked closet flange May 6, 2014
