Crack isolation membrane?
Discussion in 'Remodel Forum & Blog' started by tate16t, Apr 3, 2008.
  1. tate16t
    tate16t New Member
    Dec 26, 2006
    New York
    Can someone recommend a crack isolation membrane. I'm doing procelain tile over a concrete slab where some cracks exist.
    Thanks in advance.
  2. jadnashua
    Noble company makes some good ones. Check out www.johnbridge.com for tiling questions.
  4. tate16t
    tate16t New Member
    Dec 26, 2006
    New York
    Thanks for your response. What about a product called Ditra? I was told by a friend this is a good solution. Are you aware of this?
  5. Lakee911
    Lakee911 I&C Engineer (mostly WWTP)
    Aug 23, 2005
    Columbus, OH
    I used Ditra in my kitchen. I really liked using it. Seems a little hokey when you first start using it and putting it down, but it's worked well. It's great stuff. Pricey for what it is, but it's good.
    Jason
  6. jadnashua
    Ditra is made by www.schluter.com and is a great product. It is designed for combating deflection issues, not potentially spreading that can come from a crack. Typically, crack isolation membrane is used over and to the sides of the crack by maybe a foot or so. Ditra is designed to be used in place of cbu on a wood floor, or over a slab in its entirety. On a slab, it has an additional advantage in that the channels allow the slab to breath a little, and is a great choice over a green slab (which shouldn't be tiled otherwise for at least a month). An isolation membrane is typically quite thin but elastic. Ditra is fairly rigid and much thicker than an crack isolation membrane, making its use over only a crack problematic. It is conceivable that you may want both. Ditra does have some abilty over a crack, but that is not its primary function.
  7. tate16t
    tate16t New Member
    Dec 26, 2006
    New York
    hmmm... a lot of folks must be confused about the use of Ditra because I'm being told to use it for my purpose by multiple people.
  8. jerome8283
    jerome8283 New Member
    Oct 4, 2006
    New York
    I called Schluter and was told that Ditra can be used for my purpose. That is, to protect my tile from cracking due to potential movement of the cement floor due to existing cracks.
  9. johnfrwhipple
    johnfrwhipple BATHROOM DESIGN & BUILD for both Canada & the US
    Jul 20, 2009
    Design Work World Wide: Bathrooms Vancouver Area
    North Vancouver, BC
    Someone there told you that Ditra is A crack isolation membrane???? I think Not.
    This is a crack isolation membrane. ANSI 118.12
  10. jadnashua
    Is that slc embedding the heating wire, or is it thinset? If thinset, it appears to be WAY thicker than allowed, unless it is a medium bed mortar. If the heating is turned on too soon after installation, you can have some bad things happen.
  11. johnfrwhipple
    Jul 20, 2009
    North Vancouver, BC
    Check out the Resource Section here for more info on Crack Isolation Membranes.
Similar Threads: Crack isolation
Remodel Forum & Blog Anyone know how much sand I can mix in sealer to make crack filler? Jul 19, 2014
Remodel Forum & Blog Skim coated paneling now cracking after a year. Would eave vents help? Jan 23, 2014
Remodel Forum & Blog Plaster ceiling and wall crack repair product Aug 21, 2013
Remodel Forum & Blog ceiling paint is cracking/flaking Sep 17, 2012
Remodel Forum & Blog Foundation cracks Sep 27, 2009
