crack in toilet lid mount hole?? Fixable?
Discussion in 'Toilet Forum discussions' started by sneekeemt, Apr 11, 2011.
  1. sneekeemt
    sneekeemt New Member
    Apr 11, 2011
    Montana
    :confused:HELP!!! My toilet leaks each time it is flushed from the seat bolt. After taking it apart I noticed that there is a small hair line crack less about a quarter inch inside the bolt mount hole. Is this fixable or do have to buy a new toilet???...for such a small hole in a such a ronadom/ non-important area of the toilet???
  2. SacCity
    SacCity In the Trades
    Mar 14, 2011
    Sacramento, CA
    There is something else going on. A small crack at the seat bolt should not cause water leakage.
    More likly you are getting water from the gasket between the tank and the base of the toilet.
    You can pick up a gasket for less than $5 a pop at the local hardware store
  4. sneekeemt
    Apr 11, 2011
    Montana
    Um, no I can ee water comig out of the crack when flushed; it's diffinatley leaking from the hole! See pics.
    [​IMG]
    [​IMG]
    Any suggestions??
  5. jadnashua
    Sounds like time to replace the toilet...appears to be an internal crack. See what kind of consensus you get, but I think it's time for a new one.
  6. Terry
    Aug 17, 2004
    An old cracked $75 toilet. Let me think.............yeah, just dump it and get a new one before you have to replace floors, carpets and drywall.
    I got a call today from a homeowner that has to spend $8,000 to fix what a leaking toilet did.
  7. Gary Swart
    Gary Swart In the Trades
    Sep 1, 2004
    Yakima WA
    Look at the bright side. The Briggs was not a very good toilet to begin with. Now is an excellent time to get a quality toilet. If you had spent any amount of time around this forum, you would know that the overwhelming preference for toilets is the Toto line. Not available in discount stores, and likely you would have to have a plumbing shop order one. You can see a complete lineup of models elsewhere on this forum.
  8. hj
    quote; you would know that the overwhelming preference for toilets is the Toto line
    But not necessarily the concensus opinion. I have only installed a half dozen Toto toilets and have not had any complaints about the others.
  9. Terry
    Aug 17, 2004
    hj is right. A toilet without a crack is better then a toilet with a crack.
    We do however pull out a lot of the toilets that hj installs. They work for some, and not for others. Every once in a while we pull out Champion toilets, Cimarrons, Wellworths, Mansfield Alto, Briggs Vacuity, and I was at a church in Monroe that pinned warnings all over the bathroom about how to double flush the toilets that hj has in his home; the Eljer one-piece. That one works too. Just follow the directions pinned on the stall. Flush once, then use paper, then flush again. No worries mate! We keep the plunger handy in case you need it. But if you follow directions you should be good.
    I think that 80% can use anything without worries. I thought I was in the group too, until I would visit my daughter, and dang if I wasn't having problems with her builder grade stuff. She suffered for almost two years before she "let" me replace them.
    From the picture, I can't even see a crack though. I see adhesive around the bolt hole.
  10. sneekeemt
    Apr 11, 2011
    Montana
    It only leaks when flushed and it's usually only a drip or two, I seriously doubt that I would have to replace the sub floor. It almost appears to me that it is a design flaw and not even a crack....
    :confused:TERRY ARE YOU BLIND?:confused:
    [​IMG]
    RED = pointed out area
    YELLOW = circled out "crack"
    Green = where it leaks!
  11. Terry
    Aug 17, 2004
    I saw the seam, but I've also never seen a bowl with a seam there, nor have I ever seen a leak there.
    You have a first. Way go to.
    You have an amazing toilet.
    You might as well keep it. It only drips a little bit anyway. It's perfect.
    Yes, you too can own a Briggs, they're that good.
  12. sneekeemt
    Apr 11, 2011
    Montana
    “A sarcastic person has a superiority complex that can be cured only by the honesty of humility, that's whay it's the refuge of losers!
    I apologize if I offended you when I asked if you were "BLIND". It seemed relatively obvious from the photos that there was some abnormality in the exact location I had described. I will replace the toilet tomorrow, if there is no legitimate fix to this unusual problem! I was hoping to save the money for my first born's college fund!:rolleyes:
    Enjoy the "stool"
  13. Terry
    Aug 17, 2004
    You might try silicone or epoxy on that. It's not a crack, just a loose seam.
    There are plenty of manufacturers that would do that.
    But I would frame the picture. Here's one I like.
    I have this one in my dining room right next to my Van Gogh
    At least I have both of my ears.
    [​IMG]
    Van Gogh
  14. jadnashua
    It's a defect in the toilet...probably been there since manufacturered. Depending on where that moisture ends up, a drip or two each time flushed could, over time, create problems below in the floor. It may be small enough that it evaporates. It is not normal. Trying to fix any porcelain product that may have some moisture trapped in it is problematic and unlikely to work long term - stuff doesn't usually stick to wet surfaces, and then, even if it did, you'd have to leave it for awhile to cure. If there is an internal channel, it could already have messed up underneath. What's to say that it isn't full of water beneath that seam into the bowels of the thing?
  15. gusherb94
    gusherb94 Member
    Jan 13, 2009
    Everything
    chicago/nw IN
    If that were my toilet, and considering it's a Briggs...I wouldn't even think twice about tossing that out...
  16. Cookie
    Cookie .
    Oct 7, 2005
    Give it to a relative, lol. (one you don't like)
  17. Cookie
    Cookie .
    Oct 7, 2005
    If you need a loan on a relative, I got plenty I can offer. :)
Similar Threads: crack toilet
Toilet Forum discussions cracked toilet supply tube connector Nov 11, 2014
Toilet Forum discussions Any tips on how to tighten a toilet to the flange without cracking the toilet base? Mar 2, 2014
Toilet Forum discussions brand new Toto toilet tank cracks after filled with water. May 14, 2013
Toilet Forum discussions Toasted tank seal 110 year old toilet. Hairline crack = cannot replace seal. Feb 17, 2013
Toilet Forum discussions Toilet Tank Tiny Crack Jul 7, 2012
