Hi all,
Hope someone can give us some help with our tub, which was recently installed by a contractor. The walls in the bathroom are crooked, and and as a result, the tub is, too. The rest of the install (membrane install, tiling, etc.) is acceptable, but the tub is visibly crooked, and the tiles overhang the tiling flange.
At the front of the tub, the flange is nearly flush in one end, but set back a good 1/4" - 3/8" in the other corner and edges.
Here is the view along the side of the tub. The tiling flange is behind the tile - behind that is a Kerdi membrane, and aqua board.
I believe the contractor when he tells me that the enclosure is waterproof, but I think the look of this gap is pretty bad. He says he usually just caulks it, but I can't see that working very well in the front, where the flange is so uneven.
Does anyone have a suggestion as to how to fix? The contractor is looking at some kind of material to lay over the gap. Others have suggested caulking strips, but all reviews say that the self-adhesive they use is not very reliable.
Scott
Scott
