KULTULZ
Jack of all trades, Master of none
I have to replace/reroute a vertical waste (3" hubless iron) stack (3 story condo) as the origional builder did not route it properly (or support it properly) taking needed space in the wet wall (want to install recessed cabinet in that position.
It is SCH 40 PCV in the slab with PVC couplings above the ceiling and the actual pipe is cast iron hubless. Are there specialty PCV fittings that need to be used with the hubless pipe? It presently has a cleanout (PVC) at the base that actually juts out from the wall. I need to turn that cleanout ninety degrees (if allowed) to have a flat wall and still be accessible to snake. Is this permissable as long as an access door (18") is available allowing the cap to be removed within the wall and a snake inserted?
I want to have all the parts handy before I cut.
Thank You Gentlemen...
