Could use some help. Wall hung toilet bowl
Discussion in 'Plumbing Forum, Professional & DIY Advice' started by TheNewGuy, Apr 8, 2014.
  1. TheNewGuy
    TheNewGuy New Member
    Apr 8, 2014
    California
    So here is my issue, an old prison facility built in 1989 with wall mounted ceramic toilets attached to a cinder block wall with fixtures behind the wall located in a pipe chase, the toilets are attached via all thread going threw the wall into the pipe chase, my problem is that they packed a bunch of mortar into the hole the all thread is going threw and as i was removing the mortar to replace the all thread i noticed a small metal plate (probably to keep the all thread from moving around in the predrilled hole) that has serious rust issues, my question is, what is the best way to remove the plate inside the cinder block and the all thread so i can replace it? thanks in advance for any help :)
  2. Terry
    Aug 17, 2004
    The bowls hang on the all thread, with backing nuts and washers.
    I would chip out the washer and replace if needed. I doubt that the all thread is that bad, however, if it needs replacing too, you can tap out the block to get access to the carrier that the all-thread is attached to.
    Make sure you do that within the confines of the bowl outline, or you will be doing wall repair.
  4. hj
    The all thread should go through the plate, not be threaded in to it.
Similar Threads: help Wall
Plumbing Forum, Professional & DIY Advice HELP! Dripping sound coming from my wall! Dec 22, 2015
Plumbing Forum, Professional & DIY Advice Need Help Installing Commercial Wall Mount Faucet May 9, 2015
Plumbing Forum, Professional & DIY Advice Help identify wall faucet Jun 10, 2013
Plumbing Forum, Professional & DIY Advice help with options for comfort height bowl toilet, shelf on wall limits tank height Sep 5, 2012
Plumbing Forum, Professional & DIY Advice Help! Replace wall hung toilet in a 50 years old condo... Aug 22, 2012
