Could Not Tighten Shower Drain Nut W/Wrench....??
Discussion in 'Shower & Bathtub Forum & Blog' started by molo, Aug 25, 2012.
  1. molo
    molo Member
    Sep 23, 2006
    Cold New York
    The Story:
    We were installing a 48" shower stall over a tight crawl space. We set it in mortar before placing the shower drain kit into the base.
    We had to install the drain kit after the base was installed. There was limited access to tighten the nut that tightens the rubber washer to the base of the shower.
    What I did was placed a thick bead of silicone around the drain opening and set the drain piece into the silicone. I was then able to get below the shower and hand tighten the nut up to the bottom of the shower (but could not put a wrench on it).
    The shower is in a solid bed of mortar. My question is will this silicone/hand tighten method work?
    Thanks,
    Bill
    Edit: I know this sounds like a goofy thing to have done (and it was), but we needed the mortar to set up for the following day and could not get to a store for the drain kit. Finally, we thought we would be able to get a wrench on the nut after it was installed, but the wrench we had did not fit. So, the rest of the subfloor was installed after it was hand-tightened.
  2. cacher_chick
    Jan 5, 2008
    Test, Don't Guess!
    The best answer we could give is "maybe".
    The drain should have been installed before the pan was set.
Similar Threads: Tighten Shower
Shower & Bathtub Forum & Blog How to tighten loose shower pipe?? Jan 4, 2006
Shower & Bathtub Forum & Blog New Shower Arm will not tighten Apr 4, 2005
Shower & Bathtub Forum & Blog This has turned into a mess.......can't tighten dome enough Jan 27, 2013
Shower & Bathtub Forum & Blog How do I tighten down tub faucets if the tile wont allow access? Sep 3, 2008
Shower & Bathtub Forum & Blog Hand tighten or with wrench Jul 3, 2006
