Could first use of new basement shower cause backup in floor drain? Weird situation
Discussion in 'Plumbing Forum, Professional & DIY Advice' started by zerolast, Mar 27, 2012.
  1. zerolast
    zerolast New Member
    Mar 2, 2008
    Columbus, Ohio
    We have a basement shower which was first used today. The shower drain, sink, and toilet pipes were put in 4 years ago and we just finished the bathroom about 2 months ago. We have been using the toilet and sink with no problems for 2 months. I went into the storage area soon after the first shower and see the basement floor drain backed up with an inch or so water in about a 3 feet ring. My son noted during the shower he heard gurgling sounds and the water would backup in the shower a little bit and then "whoosh" out of the shower. This gurgling and whooshing only lasted a few minutes and the rest of his shower was normal. I checked other toilets/showers/sinks and even ran the culprit shower again and the water does not come up as I watch the floor drain. I poured water into the floor drain and the water level about 6-8 inches down stays constant. I'm obviously not a plumber but think the line was likely dry and the new water source might have caused some type of acute venting problem? Any ideas are much appreciated. Thanks, Dave
  2. hj
    There are many possibilities, but it could have had paper stuffed into it to keep odors out. It would then cause a backup until it got wet and the water flushed it out. Until it happens again, there is no real way to diagnose it.
  4. Tom Sawyer
    Tom Sawyer In the Trades
    Nov 29, 2010
    Maine
    I'm betting on paper or a rag stuffed down the pipe too
  5. zerolast
    zerolast New Member
    Mar 2, 2008
    Columbus, Ohio
    Thanks for the replies. Just ran the dishwasher and there is water around the basement drain again. So I guess there is a clog somewhere in the line.
Similar Threads: basement shower
Plumbing Forum, Professional & DIY Advice Setting Basement Shower Pan Nov 5, 2016
Plumbing Forum, Professional & DIY Advice Basement Bathroom New Shower Vent Question May 2, 2016
Plumbing Forum, Professional & DIY Advice Suggestions on a Cast Iron Drain in a Concrete Slab - Basement Shower Apr 7, 2016
Plumbing Forum, Professional & DIY Advice Basement rough-in from tub to shower Sep 25, 2015
Plumbing Forum, Professional & DIY Advice Basement Shower Plumbing Aug 19, 2015
