Cost to replace lead pipes to copper
Discussion in 'Plumbing Forum, Professional & DIY Advice' started by SC79, Jul 8, 2008.
  1. SC79
    SC79 New Member
    Jul 8, 2008
    I am considering buying a foreclosed property in NJ. It was vandalized by the previous owners and they took out the water meter. The water company cut & capped the service. The house is connected with lead pipes to the main line, which runs across the street (apprx 25-30 ft from the basement). In order for me to restore the water service, I was told that I need to bring it up to code by replacing the lead line with copper line.
    Does anyone have any idea how much it may cost me? Thanks!
  2. Gary Swart
    Gary Swart In the Trades
    Sep 1, 2004
    Yakima WA
    Usually it is the city's responsibility to bring the water to your property and install the meter. Certainly they would insist on doing any street opening and closing. You might have to pay for the meter, but that is arguable in my opinion since you didn't own the property at the time of the theft. After the meter, it is your problem, but I would go with copper although you can use PVC underground from the meter to the house, but not inside. As far as cost, it is hard to determine from afar because of the many variables involved. Certainly copper is very expensive now days, but 39 feet of copper should not bankrupt you. However, labor can be even more than materials. The line from the street to the house in your areas needs to be fairly deep, so unless you have a source of cheap grunt labor, you might look into having it tunneled or contracted to a backhoe operator. Verify what I have said regarding the city's responsibility with the city water department.
  4. jadnashua
    It very much depends on the area. If the road has to be torn up, it can get quite expensive. You may have to pay for that, it just depends.
Similar Threads: Cost replace
Plumbing Forum, Professional & DIY Advice how much does copper tubing used my plumber to replace shower body cost? Oct 27, 2012
Plumbing Forum, Professional & DIY Advice Replace Main Shut-off Valves - Cost May 12, 2010
Plumbing Forum, Professional & DIY Advice Shower cartridge replacement cost Jul 18, 2009
Plumbing Forum, Professional & DIY Advice plumers cost to replace hosebib Dec 15, 2008
Plumbing Forum, Professional & DIY Advice Outrageous cost of water heater replacement Feb 25, 2005
