Cost to have gas line ran to stove?
Discussion in 'Plumbing Forum, Professional & DIY Advice' started by enviroko, Aug 16, 2007.
  1. enviroko
    enviroko New Member
    Apr 2, 2007
    Hi, can anyone give me a ballpark figure for having the following job done?
    We currently have an electric stove but our natural gas line runs directly under (full basement) the stove and we plan to switch to gas. So all that I believe needs to be done is to tap into this line and run a line up through the floor to the stove.
    I want to have someone come in and do it to make sure that is to code but I don't want to get taken.
  2. GrumpyPlumber
    GrumpyPlumber Licensed Grump
    Jun 18, 2007
    Plumber, self employed
    Licensed Grump
    Too many unmentioned variables there.
    Joist direction...any drilling?, gas main size & number of BTU's attached vs length, availability for connection to the main...will it need to be threaded? or is there a tee available?
    Best to get a couple of estimates...or take pics, post them and hope we can see whats there.
    Could be a $150 quicky, could be a whole day $1,000+....
  4. enviroko
    enviroko New Member
    Apr 2, 2007
    * The pipe is 1" OD & very easily accessable.
    * Runs parallel to the joists but it needs to move one joist over to go up through the floor behind the stove. I will drill hole before the plumber comes in.
    * The pipe has no T, pipe will need to be threaded. It is currently a straight pipe that runs right on past the stove area.
    * BTUs I don't know.
  5. statjunk
    statjunk DIY Senior Member
    Jun 28, 2007
    I'm no expert but I did sleep at a Holiday Inn last night.
    I'd say between $250 and $500.
    Tom
  6. tjbaudio
    tjbaudio Sound and Light Suppervisor for a School District
    Dec 6, 2005
    sound and light suppervisor for a school district
    Wisconsin
    I would let the plumer do the drilling. He/she may drill first or may get the T in and then drill to where it ended up. You want the min size hole you can get. Drilling first and then having to ream out the whole would suck. Also what if you slip and cut the pipe? Probably wont damage it too bad but it may make for a problem. All in all I think the drilling is the minimal part of the project. You wont save much time of money and may cost extra!
  7. markts30
    markts30 Commercial Plumber
    Sep 25, 2006
    Commercial Plumber
    Phoenix, AZ
    What else is being fed by this line?
    You can only run so many BTUs on a given length of 1"...
    Does your water heater, clothes dryer, furnace, bar-b-que etc run on the same line?
    How about a gas fired pool heater etc...
    Once you know how many BTUs you are drawing from that line, you can figure if the new fixture will overtax it (some gas ranges can run upwards of 85-100,000 BTUs though most are less)
    A 1" pipe with the furthest fixture having 80' of pipe to it can only support 222,000 BTUs
    As well, be aware that cutting a t into the middle of an existing gas line is going to be a pain... The plumber is going to have to use a left and right nipple and the whole system will likely have to be re-tested and inspected if the work is going to be permitted (I would advise to have a permit pulled and inspection done...)
  8. cwhyu2
    cwhyu2 Consultant
    Aug 11, 2007
    Consultant
    Cincinnati OH
    trak pipe
    Trak pipe is the way I would go.But you need to have someone trained
    to install this product.Look it up.
  9. GrumpyPlumber
    Jun 18, 2007
    Licensed Grump
    Here lies the irony, I'm certified in tracpipe and wardflex (like thats a big deal).
    I still prefer hard piping over it.
  10. lee polowczuk
    lee polowczuk New Member
    May 30, 2007
    Florida
    i once had this done... listen to this....
    i called the plumber.... and he started dragging out this very thick book.. looked at my project... started doing all this estimating stuff.... came up to 1300.
    i said thanks... somehow i got taken for 35 dollars for the estimate.
    called the gas company.... done for 225.
    second house.... had a friend do it... about 150 including materials..
    both of these jobs were very similar... under house access two runs with a couple of 90's.
    both were black pipe... code here allows flexible...but i wanted black pipe
  11. Master Plumber Mark
    Master Plumber Mark Master Plumber
    Feb 6, 2005
    Sensitivity trainer...healey-feeley.....
    gas line run
    I usually just tell people that our Minimum for fooling
    with a gas line is $250.00..
    we cant come out for less and ballparking the job
    usually its a not -to-exeed price of $450..
  12. hj
    gas company
    Our gas company is NOT ALLOWED to do any piping after the meter, regardless of the amount. And they value their cushy jobs too much to rist side jobs.
  13. Chris75
    Chris75 Electrician
    Aug 12, 2007
    Electrician
    Litchfield, CT
    Don't forget you will need an electrician to add a 115v receptacle for the gas stove... unless you were going to do that work yourself...
  14. jadnashua
    If you go with a dual-fuel stove, then you'd need 240vac...while you're at it, another circuit for a vent hood, and maybe more to bring the room up to code while you're at it.
Similar Threads: Cost line
Plumbing Forum, Professional & DIY Advice Failed Well Rehab Costing $1000 Jan 17, 2016
Plumbing Forum, Professional & DIY Advice Install Cost Apr 28, 2015
Plumbing Forum, Professional & DIY Advice Cost of new gas boiler for 6000sq ft home Feb 4, 2015
Plumbing Forum, Professional & DIY Advice u drain trap removal cost estimate Jul 27, 2013
Plumbing Forum, Professional & DIY Advice If you had supplies at no cost, would you choose PVC or CI May 24, 2013
