Corroded Tub Drain
Discussion in 'Shower & Bathtub Forum & Blog' started by phxrt, May 20, 2006.
  1. phxrt
    phxrt New Member
    May 20, 2006
    I am replacing an old fiberglass bathtub unit and installing a steel/porcelain tub. The old tub overflow/drainpipe had come loose and corroded and the brass pipe stub coming out of the concrete (just above the p trap) is only about 3/4" long. It is pretty thin and has a crack in it. Home Depot said I could use JB Weld on it to patch the crack, then use a compression fitting that would screw into ABS pipe. I really don't want to have to break up the concrete and get into the ptrap area. Will this method work? Thanks, Richard
  2. Terry
    Aug 17, 2004
    Break up the concrete and do it right.
    If the thin brass pipe is cracked, it will only get bigger with more stress.
  4. Cass
    Cass Plumber
    Nov 12, 2005
    Terry is right. Not only that but the trap under the concrete my be totaly gone or just ready to go and after you do the job you might have to remove the tub and break up the concrete a year or so from now anyway, so just do it now.
Similar Threads: Corroded Drain
Shower & Bathtub Forum & Blog shower drain cover corroded Apr 5, 2006
Shower & Bathtub Forum & Blog Corroded bathtub in a concrete condo - solutions? Sep 17, 2005
Shower & Bathtub Forum & Blog Roman Tub/Drain...Want to Remove Monday at 10:06 AM
Shower & Bathtub Forum & Blog Delta Acrylic Bathtub Drain Sealant Feb 14, 2017
Shower & Bathtub Forum & Blog Offset PVC Solvent weld drain in Acrylic Shower base fit Feb 9, 2017
