correcting crooked toilet flange
Discussion in 'Toilet Forum discussions' started by astro46, Jan 9, 2007.
  1. astro46
    astro46 New Member
    Dec 7, 2005
    Chicago
    this is in a basement washroom. the wall behind the toilet was not square to the room. at some point someone installed a pvc(?) flange, into what looks like a clay closet bend, such that the toilet bolts alignment would allow the toilet to be mounted parallel to the crooked wall.
    i am straightening the wall. now the flange is crooked in relation to the wall. if one bolt is 12" from finished wall the other will be 3/4" closer. ie, 11 1/4" from the wall.
    what is the easiest way to fix this situation?
  2. jadnashua
    Put a repair flange on with the T-bolts where you want them?
  4. Verdeboy
    Verdeboy In the Trades
    Jun 12, 2006
    Most flanges allow you to adjust the positioning of the bolts slightly. Maybe that's all you need to do to get it to come out even with the straightened wall.
  5. astro46
    astro46 New Member
    Dec 7, 2005
    Chicago
    i'll look at flange repair kits, to see if they may help.
    the flange has both simple slot and long slots which allow for adjustment. unfortunately the simple slots are the ones closest to correct position.
    thanks.
    i would have replied sooner, but the auto reply notification isn't working.
Similar Threads: correcting crooked
Toilet Forum discussions Level, but slightly crooked toilet Mar 30, 2014
Toilet Forum discussions Need to Repair Lead Closet Flange but the Pipe is Crooked! Aug 21, 2013
Toilet Forum discussions Toilet Flange is Crooked Aug 21, 2010
Toilet Forum discussions crooked and broken cast iron flange in concrete slab Jan 2, 2010
Toilet Forum discussions Toto Drake "Crooked" Jul 16, 2007
