Giles
Retired tool & Die and Mechanic
Some time ago, a friend gave me some circuit breakers. One in question is a SIEMONS QPF 120.
On the side of the breaker, the attached ground wire is marked "Panel Neutral". Then just above this , is a terminal marked "Load Neutral". The other terminal is not marked but has white paint above it.
The breaker still had short wires attached and the hot was connected to the white marked terminal.
I think the neutral should be hooked to the white marked terminal as this is how I have done it before.
How should this be hooked up?
