Correct screw orientation ?
Discussion in 'Electrical Forum discussion & Blog' started by Agu, Jul 17, 2009.
  1. Agu
    Agu New Member
    May 21, 2009
    Tampa, FL
    Replaced all the outlets and switches in my house with the help of an electrician friend. Could have done it myself but with an older home I wanted to have him confirm everything was done right and up to code. He did find and correct some questionable wiring, for which at some time he'll call in the favor. In the future he'll have me helping him on some really miserable job and I'll have to smile and pretend I'm enjoying myself. ;)
    After we finished I replaced all the switch plates with new plates.
    After a few weeks he came by and informed me all my plates were installed wrong. All the screw slots holding the plates were up and down (perpendicular to the floor). He informed me all screw slots should be horizontal (parallel to the floor).
    So who's right and why?
    The answer that we're both anal retentive with compulsive personalities is not correct btw .
  2. Speedy Petey
    Speedy Petey Licensed Electrical Contractor
    Jun 16, 2007
    NY State, USA
    They MUST be on a 45 degree angle. This is extremely important. I have seen whole houses fail inspection because of it.
    This can be found in the district code addendum XR7-4Jc.
    Please don't make this mistake again. ;)
  4. jimbo
    jimbo Plumber
    It has to do with the way that electromagnetic flux lines "leak" off the head of the screw. If you put the screws in wrong, it will cause interference on TV's and computers.
  5. Speedy Petey
    Jun 16, 2007
    NY State, USA
    And birth defects. Don't forget birth defects!!
  6. Agu
    Agu New Member
    May 21, 2009
    Tampa, FL
    Does that have anything to do with the belief that loose electrons will collect in a horizontal screw slot ?
  7. Agu
    Agu New Member
    May 21, 2009
    Tampa, FL
    BTW, I understand painters have their own rules. Their technique is to tighten the screw until the plate cracks, back off a half turn, and blame the electrician.
  8. Bobelectric
    Bobelectric Electrical Contractor
    Feb 16, 2009
    Eighty Four,Pa. 15330
    Balance,We need Balance!
  9. Billy_Bob
    Billy_Bob In the Trades
    Apr 2, 2008
    I should think you would want to verse yourself in the various aspects of
    Screw Theory by Sir Robert Stawell Ball...
    Screw Theory...
    http://en.wikipedia.org/wiki/Screw_theory
    [​IMG]
  10. hj
    amen
    quote; Screw Theory...
    Isn't that the motto of most handymen? As for the original question. Throw the screws away and glue the plates to the wall. The screw holes will allow air circulation to prevent heat buildup in the boxes. By the way, did you check the screw orientation on the ones holding the wires?
  11. jbfan74
    jbfan74 Electrical Contractor
    Jun 14, 2007
    Newnan, GA
    Screws always up and down!
    This allows the dust to fall from the screw to the floor where the cats have something to play with!
  12. hj
    screws
    Wrong! If the slot is up and down, the dust does not accumulate. Horizontal it will build up until it gets heavy enough to collapse, and then the cats will have a large ball to play with. Why are you still using slotted screws? Phillips will eliminate the uncertainty.
  13. PEW
    PEW DIY Senior Member
    No one covered the summer to winter rotation requirements.
    I always do mine late spring and late fall when I change the air in my tires. Makes it easy to remember.
  14. Jeff1
    Jeff1 New Member
    May 24, 2006
    So Cal
    What about the Northern vs Southern Hemisphere adjustments for vortex and magnetic differentiation?
  15. Agu
    Agu New Member
    May 21, 2009
    Tampa, FL
    I live in SW Florida, do those requirements also apply in subtropical climates? I thought that only applied in climates where the cold caused shrinkage?
Similar Threads: Correct screw
Electrical Forum discussion & Blog Can Screw In Fuses be Safe If Sized Correctly? Aug 25, 2013
Electrical Forum discussion & Blog Correcting Exposed Direct Burial Splices Jun 1, 2016
Electrical Forum discussion & Blog Dual switches not working correctly after light modification Jul 19, 2015
Electrical Forum discussion & Blog Do I have the correct type of cable? Mar 7, 2015
Electrical Forum discussion & Blog Correct type of wire to connect to A/C outside unit. Mar 2, 2014
