SergeFlorida
Just recently moved to Florida and the house I bought uses well water. I had city water all my life and have no in-depth knowledge in this subject. The house came with water boss softener that was connected to hot water line only. Cold water was going directly from well untreated. All showers and toilets in the house covered with layers of rusty stuff and water smells like iron. No sulfer smell. I called to local culligan shop and they sent sales man who did some basic water testing. Below some test results:
Hardness - 20.0
Iron 3.5
ph - 7.5
Sulfur - 0.0
Alkalinity - 306
TDS - 375
The sales guy give me a quote of $2500 for water softener Medalist and $2900 for Gold model. Not sure about price range for this type of equipment but I decided to go with used stuff as I have read that with the proper care the water softener can last for a long time. I found some deal and bought the same model used (3 years old) water softener and it also came with chlorination- dechlorination system. The only thing that was missing is injection pump. The guy who sold me this system gave me all papers including connection diagram and I used it as blue print for my installation. Once everything was ready I tried the system without chlorine and the water become much softer but it did not fix iron problem with toilet stains. Once I installed chlorine pump everything work just fine for the exception of some kind of iron smell or may be similar smell like wet rug. It is much less then before but still annoying. It is stronger in the morning and on the third day before regeneration (it is set to default once in 3 days) . From what I know smell can come from untreated bacteria or chemicals. I did some water testing after mixing tank to see if there is enough chlorine and the test strip color changing system does not show me exactly the amount of chlorine in the water, but it shows none after carbon filter and water softener. To make long story short here are my questions:
Based on the diagram Carbon filter goes before water softener and it is intended to remove chlorine to protect resin in softener from damage. I assume it is correct set-up and I just want to see if there is a different set-ups possibilities. My other question when do I need to change carbon beans and resin beans in water softener? Based on statistic history log there are 350 regenerations cycles processed by softener for the its working life. My final and main question is how to get rid of the smell. Any suggestions?
Hardness - 20.0
Iron 3.5
ph - 7.5
Sulfur - 0.0
Alkalinity - 306
TDS - 375
