Corner Shower on Exterior Walls
Discussion in 'Shower & Bathtub Forum & Blog' started by wvsamdog, Nov 11, 2005.
  1. wvsamdog
    wvsamdog New Member
    Nov 11, 2005
    Here is my situation...
    I am about to install a one piece neo-angle shower in a corner with 2 exterior walls. I have determined that this may be a problem in the future if any work needs to be done on the plumbing behind the shower. There would be no way to access pipes except to remove shower or cut through exterior of house. Two things that would be major headaches.
    How big of a problem am I getting myself into?
    Keep in mind space is very limited and using the exterior walls are the only way the shower will fit.
  2. jeffreyhel
    jeffreyhel New Member
    Nov 4, 2005
    I wouldn't worry about it. Moen and Delta and others make repair plates if the valve needs to be replaced. Just make sure if you are in a cold climate area to insulate the walls and pipes well.
Similar Threads: Corner Shower
Shower & Bathtub Forum & Blog Corner round shower help! Mar 11, 2015
Shower & Bathtub Forum & Blog Preventing Build Up in Shower Corners: Installation Tips for NobleSeal CIS Nov 28, 2014
Shower & Bathtub Forum & Blog How to do shower wall corners. Dec 15, 2013
Shower & Bathtub Forum & Blog Do "L" shaped shower rods make for a reliable shower design - Small, Corner Shower Jul 13, 2013
Shower & Bathtub Forum & Blog Leak under base of corner shower stall doors after cleaning, re-setting and caulking Mar 30, 2013
