corner shower drain help - please-
Discussion in 'Shower & Bathtub Forum & Blog' started by tinhorse, Dec 21, 2009.
  1. tinhorse
    tinhorse New Member
    Dec 21, 2009
    port alberni, bc, canada
    Hi I am new to remodeling a bathroom and need a little help. I am wanting to install a corner shower in my basement bathroom. I have two walls which measure 33 1/2' and 32 1/4" in which i am planning to place my shower walls on. The drain is in an odd spot though measuring 19" from the back wall and 14" from the side wall. Can I install a corner shower base without moving the drain in the concrete floor? or do I have to move the drain to be able to install the shower base. Not too sure how they work. thanks for any advice you may have.
  2. jadnashua
    Pre-formed bases have their drain where they want, and it is seldom where your drain currently is! Fact...
    So, your choices are move it, or build a custom shower. That is a fairly small shower, and will barely be above the minimum required to meet code. Many people would find it confining. It'll work, but if you can make it a little bigger, you'd find it more pleasant.
    Building a custom shower isn't all that tough, but like anything, there are critical things to ensure you get right or it will fail.
    If the existing drain is quite old, it may be worth it to tear the current drain out so you can judge the overall state...it would be a pain to build a new shower using the old drain and trap and to find out that it is rotten through and leaks.
    Check out www.johnbridge.com for help in building a tiled shower.
  4. hj
    drain
    The drain will typically be either 12" from both rear walls, 16", or 18" depending on the make and model. But it is a FIXED dimension so you either move the walls to make it work or relocate the shower drain in the floor.
  5. tinhorse
    tinhorse New Member
    Dec 21, 2009
    thanks, that's what I thought. It is only a couple of inches so it should not be a huge ordeal.
Similar Threads: corner shower
Shower & Bathtub Forum & Blog Corner round shower help! Mar 11, 2015
Shower & Bathtub Forum & Blog Preventing Build Up in Shower Corners: Installation Tips for NobleSeal CIS Nov 28, 2014
Shower & Bathtub Forum & Blog How to do shower wall corners. Dec 15, 2013
Shower & Bathtub Forum & Blog Do "L" shaped shower rods make for a reliable shower design - Small, Corner Shower Jul 13, 2013
Shower & Bathtub Forum & Blog Leak under base of corner shower stall doors after cleaning, re-setting and caulking Mar 30, 2013
