Corner Shower Advice
Discussion in 'Shower & Bathtub Forum & Blog' started by dw85745, May 16, 2012.
  1. dw85745
    dw85745 Member
    Oct 14, 2004
    Tucson, Arizona
    I need to install a corner shower 38 x 38 with a fiberglass pan.
    Plan is to use imitation marble on stud walls and possibly glass for sides and door.
    Concerns I have are:
    1) Glass on side wall which butts up against lav vanity (using rain glass or some other opaque glass) will still be visible from inside shower
    2) Sealing the lav top to the glass side wall to keep water from lav top running down between the two.
    3) Would prefer walls to go to ceiling instead of 5-6 feet.
    Only solutions I can think of so far is: Higher glass wall -- or --
    drop the glass walls and go with a 2x2 stud wall either secured on the top of the fiberglass pan (???)
    or beside the pan -- if there is enough room.
    Suggestions appreciated for better alternatives.
Similar Threads: Corner Shower
Shower & Bathtub Forum & Blog Corner round shower help! Mar 11, 2015
Shower & Bathtub Forum & Blog Preventing Build Up in Shower Corners: Installation Tips for NobleSeal CIS Nov 28, 2014
Shower & Bathtub Forum & Blog How to do shower wall corners. Dec 15, 2013
Shower & Bathtub Forum & Blog Do "L" shaped shower rods make for a reliable shower design - Small, Corner Shower Jul 13, 2013
Shower & Bathtub Forum & Blog Leak under base of corner shower stall doors after cleaning, re-setting and caulking Mar 30, 2013
