copper tubing wall thickness in propane application
Discussion in 'Electrical Forum discussion & Blog' started by Darzo Olesko, Nov 17, 2009.
  1. Darzo Olesko
    Darzo Olesko New Member
    Nov 17, 2009
    B.C. Canada
    What type of 1/2 inch copper tubing-K or L-is acceptable for use in propane lines? ..K is the thickest, at 0.049, but will L at 0.040 be ok? I'm running a 50 foot line between my tank and a generator, should I buy K or L, or does it even matter? ( No building codes where the cabin is, so whatever is safe + appropriate..)
  2. Billy_Bob
    Billy_Bob In the Trades
    Apr 2, 2008
    For that I would find a local building inspector in a nearby city (where permits are required) and ask what would be required there. Type of line, depth of burial, and any other requirements. Then do what they say.
    Around my area, the building inspectors have certain hours where you can go and ask them questions.
    My thinking for doing this is that there are different areas, different weather conditions, different ground conditions, etc. And the "locals" would know about any problems typical to your specific area.
    Maybe the ground is very rocky in a certain area and these rocks can puncture tubing, so they would require sand or a certain tubing?
    Or maybe the ground freezes in that area and they might require a certain tubing or burial depth?
    Or somewhere like Arizona it gets to be so hot things will melt! A problem local to that area.
    Who knows? Anyway if you ask a local, you will get the best advice for your specific area.
  4. hj
    tubing
    Normally we use "L". Do not use ACR refrigeration tubing, usually specified as 5/8" rather than 1/2", because that is too thin for safety. It is usually labeled 5/8" rather than 1/2" even though it is the same size.
Similar Threads: copper tubing
Electrical Forum discussion & Blog City Light leader fell for ‘Indian’ copper con Jun 24, 2014
Electrical Forum discussion & Blog using copper waterlines under slab for additional ground ? Mar 25, 2013
Electrical Forum discussion & Blog Joining allum nm to copper nm Jun 6, 2012
Electrical Forum discussion & Blog copper pipes under mobile home (doublewide) Dec 11, 2010
Electrical Forum discussion & Blog bonding/grounding copper pipes Nov 18, 2010
