Copper Supply Line Questions
Discussion in 'Plumbing Forum, Professional & DIY Advice' started by maxmitchell, May 10, 2011.
  1. maxmitchell
    maxmitchell New Member
    Mar 8, 2007
    Texas
    Thank You!
  2. jimbo
    jimbo Plumber
    San Diego, CA
    The easiest is a riser with preformed end for faucet or ballcock. If you don't use premade risers, you have to have a special beading tool to make a ridge on the the copper so the flat washer and nut will retain the copper and not allow it to pull out of the fitting. The cone washer alone seals well, but is not a tight enough grip tp prevent pull-out.
  4. maxmitchell
    Mar 8, 2007
    Texas
    Thank You!
  5. cwhyu2
    cwhyu2 Consultant
    Aug 11, 2007
    Consultant
    Cincinnati OH
    I used cp copper tubes with the flat plastic washer but that was brass to brass.Brass nuts to brass fill valve.
Similar Threads: Copper Supply
Plumbing Forum, Professional & DIY Advice 3/8 OD 1/4 nominal soft type L copper supply for toilet or lav? Today at 11:18 AM
Plumbing Forum, Professional & DIY Advice Bending 3/8" chromed copper supply pipe to toilet Feb 20, 2017
Plumbing Forum, Professional & DIY Advice Replacing Copper Water Supply Line with PEX? Feb 2, 2017
Plumbing Forum, Professional & DIY Advice Copper Flare nut on Main Supply line Jan 19, 2017
Plumbing Forum, Professional & DIY Advice Copper supply piping - No Y fittings? Feb 26, 2016
