copper stub ells into shower valve
Discussion in 'Plumbing Forum, Professional & DIY Advice' started by Didymus21, Mar 26, 2014.
  1. Didymus21
    Didymus21 New Member
    Dec 22, 2013
    Portland, Oregon
    Had extra propex copper stubs. Does this seem like a reasonable use of them? Anyone see a problem with this? My other thought was to solder a propex Fitting to a 90 deg street, or something to that effect.
    Picture is below.
  2. Didymus21
    Dec 22, 2013
    Portland, Oregon
    It'd probably help if I attached the picture.
  4. SHR
    SHR Member
    Mar 9, 2014
    Journeyman Plumber
    Minnesota
    Expensive, but a great idea! Those will work good and help your install look great.
    You soldered all of your joints to the rough-in valve so neatly that I can not even see any solder around the joint. Boy, you are good.
  5. Terry
    Aug 17, 2004
    That works for me! :)
  6. Didymus21
    Dec 22, 2013
    Portland, Oregon
    Oh boy, wish I could accept that compliment! I actually haven't soldered anything yet...wanted to make sure it was a sound idea first. Thanks for the feedback.
  7. Gary Swart
    Gary Swart In the Trades
    Sep 1, 2004
    Yakima WA
    I realize you had those ells on hand, so good idea to use them. Most of us just use short nipples, threaded adapter, and regular elbows. They aren't pretty, but hidden behind walls so pretty really doesn't count.
  8. hj
    quote; Most of us just use short nipples, threaded adapter, and regular elbows.
    I guess I am NOT 'most of us', because I would NEVER use a threaded connection when the valve has sweat joint capability. I was going to comment that there might not be enough solder on the joints to have made a good seal, until you stated that they were not soldered yet.
  9. SHR
    SHR Member
    Mar 9, 2014
    Journeyman Plumber
    Minnesota
    I kinda figured that but could not resist the comment. That should end up being a nice install.
    I also never use threaded adaptors anymore on shower valves with solder connections available. When asked, most people I talk to about using the threaded adaptors say they use them in order to make the valve easier to remove if necessary. But in order to remove the threaded connections you still have to cut the copper...so nothing gained by the adaptors except more potential for leaks. As long as all plastic parts are removed from the rough-in valve it is just a really big fitting.
  10. Gary Swart
    Sep 1, 2004
    Yakima WA
    Not to start a war on this, and I certainly yield to HJ's experience and expertise, but I use the threaded adapters into valve bodies to avoid possible damage to the valve. Now, I'm a DIY and while I have never had a solder joint fail, I do not rate myself anywhere near a professional, and perhaps I'm being overly concerned about this. So, by all means if you are comfortable with soldering the pipe into the valve, do it.
  11. Didymus21
    Dec 22, 2013
    Portland, Oregon
    I do have one concern. The ells have a decent amount of play in the valve, while the vertical shower head portion does not. Do I need to be concerned about that? I know soldering will fill the gaps and tighten the joint, but would you consider that a weakened joint?
    I think I cut the ells too short, and due to the bend, I'm entering the smaller diameter part of the stub. I'd really appreciate feedback on this.
    If need be, I wouldn't hesitate to scrap them and re-do it.
  12. DaveHo
    DaveHo Member
    Mar 12, 2010
    SE PA
    That's the exact configuration I used for my shower valves. I didn't trim the Propex ells & don't recall them feeling loose in the rough in body. They've been in service for more than a year now. No issues. You using propane or MAPP? I have a MAPP torch & it still took a bit of time to get the valve body hot enough to sweat properly. I don't think I'd try it with propane.
  13. Didymus21
    Dec 22, 2013
    Portland, Oregon
    [video=youtube;sWQTHaHuods]https://www.youtube.com/watch?v=sWQTHaHuods&feature=youtube_gdata_player[/video]
    Here's a video showing what I mean.
  14. BobL43
    BobL43 DIY Senior Member
    Mar 25, 2011
    Retired Industrial Automation controls/tech s
    Long Island, NY
    Can't view it, as it seems to be in your "private" Youtube folder
  15. Didymus21
    Dec 22, 2013
    Portland, Oregon
    Should be fixed, sorry.
  16. DaveHo
    DaveHo Member
    Mar 12, 2010
    SE PA
    That looks extremely loose. Do you still have the pieces you cut off? How much play do those have? How much play in the shower head pipe?
  17. Didymus21
    Dec 22, 2013
    Portland, Oregon
    I do still have the pieces I cut off and when inserted they don't have nearly as much play. The shower head pipe has little to none.
    I think I probably blew it on those and will need to cut new pipe. I may be able to reuse them for a fixture if there is enough tip to still go through some drywall. Oh well, lesson learned.
  18. BobL43
    Mar 25, 2011
    Long Island, NY
    yup, live and learn; we all do it one time or another. repeat, repeat.............
  19. jadnashua
    You might try the v-shaped inside pipe shaping bit on most pipe cutters...it may reform the end enough to give you a tighter fit.
  20. Didymus21
    Dec 22, 2013
    Portland, Oregon
    Good suggestion, I tried and it didn't make much of a difference. I ended up just buying two street 90's and a male fitting that will couple the 90's with my propex lines. Much better joint!
  21. yngwie_69
    yngwie_69 New Member
    Sep 8, 2009
    Prince Rupert, BC
    that is loose, but your joints look pro, i dont think you will ever have a problem, it will def last till next reno. If u cleaned flux ur good. but all pipe that is bend like that thins the copper faster cause of streching
Similar Threads: copper stub
Plumbing Forum, Professional & DIY Advice IKEA, Help connecting with 1-1/4" copper stub out Aug 17, 2016
Plumbing Forum, Professional & DIY Advice Tub spout setscrew poked hole in copper stub Aug 6, 2015
Plumbing Forum, Professional & DIY Advice Advice on bar sink hookup: PEX --> Copper Stub Out --> Faucet Sep 14, 2012
Plumbing Forum, Professional & DIY Advice pex to copper fixture stub outs Jan 22, 2008
Plumbing Forum, Professional & DIY Advice Bending 3/8" chromed copper supply pipe to toilet Today at 8:27 AM
