Copper Pipes Touching Each Other
Discussion in 'Plumbing Forum, Professional & DIY Advice' started by chefwong, Oct 12, 2011.
  1. chefwong
    chefwong Member
    Jun 14, 2006
    District of Columbia
    Just finished the RO for the hot water Feed. Next is the cold water.
    Both are running parallel to each other horizontally.
    Where I go vertical to the drop ear, should I avoid the copper touching each other or is it okay to just lay both vertical and where one touches the other copper....just slip a small piece of pipe insulation between them.
    [​IMG]
  2. Tom Sawyer
    Tom Sawyer In the Trades
    Nov 29, 2010
    Maine
    Avoid them touching. In some cases electrolysis can occur and pin hole the pipe there. I would find something more substantial than paper, it will wear through. Perhaps a strip of plastic from a milk jug
  4. hj
    quote: In some cases electrolysis can occur and pin hole the pipe there.
    How can "electrolysis" occur when both are the same metal? Wear is a more likely cause of failure. Either solder the two lines together so they CANNOT rub against each other or insert a substantial piece of material between them and secure it tightly.
  5. chefwong
    chefwong Member
    Jun 14, 2006
    I ended up using some 45's , 90s and just bumped it in/out
    [​IMG]
  6. kreemoweet
    kreemoweet Member
    Sep 7, 2009
    Seattle. WA
    There are special copper fittings available for use in such situations, called "crossover couplings". Very handy in cases where
    it is desirable to keep the pipes in a single plane.
Similar Threads: Copper Pipes
Plumbing Forum, Professional & DIY Advice Need advice on repairs of copper pipes at water heater Nov 27, 2016
Plumbing Forum, Professional & DIY Advice Residue in Copper pipes: C-Flux Nov 21, 2016
Plumbing Forum, Professional & DIY Advice Pressure testing copper pipes Sep 24, 2016
Plumbing Forum, Professional & DIY Advice Extra long copper pipes Aug 19, 2016
Plumbing Forum, Professional & DIY Advice Green Buildup on Copper Pipes: Big issue or not? Aug 9, 2016
