Copper pipe touching pressure treated wood
Discussion in 'Plumbing Forum, Professional & DIY Advice' started by britta, Sep 22, 2006.
  1. britta
    britta New Member
    Sep 22, 2006
    Hi. We are in the process of having a deck built and have to decide on the type of railings to use. I would prefer not to use wood so I found some companies that sell galvanized aluminum rails in specific lengths but they corrode when touching pressure treated wood and have to have a special washer between the aluminum and the wood. We also wanted the ballusters to be horizontal between posts and thought copper pipe might be a good choice. I need help with the pros and cons of using copper. The pipe would be about 7 feet long between posts in 3 rows. Here are my questions:
    What happens when copper touches PT wood?
    What color does it turn when it has aged nicely?
    Any idea on rough price for (roughly!) 250 feet of maybe 5/8" pipe? I live in Atlanta and am sure I can find it locally...
    Any other info would be greatly appreciated!! Thanks!!:confused:
  2. Cass
    Cass Plumber
    Nov 12, 2005
    #1 I don't know
    #2 Copper will turn brown & or green over time.
    #3 250' of 1/2" copper will run you in the neighborhood of $500.00
  4. Gary Swart
    Gary Swart In the Trades
    Sep 1, 2004
    Yakima WA
    I don't believe they make 5/8" copper pipe. It comes in 1/2" and 3/4", but not 5/8". Copper prices have gone through the roof in recent times so be prepared for a jolt. You should check with your local suppliers as to their current prices.
  5. dubldare
    dubldare Plumber/Gasfitter
    Sep 14, 2005
    Plumber/Gasfitter
    MN/ND
    The old 'ID' versus 'OD' debate...
  6. Bob NH
    Bob NH In the Trades
    Oct 20, 2005
    New Hampshire
    If someone is selling you galvanized aluminum rails he is an idiot or a faker. There is no such thing.
    There is a product called Galvalume which is aluminum and zinc coating on steel. http://www.steelroofing.com/ The aluminum/zinc coating would also corrode when in contact with the copper in the treated wood.
    If you are going to insert the pipes into wooden posts, you could easily isolate aluminum (say aluminum heavy-wall conduit) by putting a short piece of shrink tubing at each end where it enters the post. Aluminum forms an oxide coating and will not remain shiny.
    Check with your code requirements. If the deck is more than 30" above the ground, you may need a railing that is at least 36" high and will not pass a 4" diameter ball at any place. Three horizontal rails won't pass that standard.
    Seven ft long copper pipe will probably not pass the requirement to withstand 200 pounds at any point on the railing.
    I think stainless steel costs about the same as copper now, and is a lot stronger. I have seen railings made with stanless cables. You need strong posts to withstand the tension.
  7. Winslow
    Winslow Plumber
    Dec 30, 2005
    Hawaii
    1/2 copper pipe is 5/8 outside diameter, 1/2 is the inside diameter.
  8. hj
    tubing
    If you want 5/8" o.d., (1/2" i.d.) go to a plumbing store. If you want 5/8" i.d., (3/4" o.d.), go to a refrigeration supply company. But, 1/2" copper, even type "K" would be mostly cosmetic because it would not resist very much lateral force and would distort very easily.
Similar Threads: Copper pipe
Plumbing Forum, Professional & DIY Advice Any idea what a plumber might charge for repairing a copper pipe? Mar 19, 2017
Plumbing Forum, Professional & DIY Advice Should I replace copper pipe? Mar 14, 2017
Plumbing Forum, Professional & DIY Advice Attaching new PVC drainpipe to copper stub out Mar 2, 2017
Plumbing Forum, Professional & DIY Advice Bending 3/8" chromed copper supply pipe to toilet Feb 20, 2017
Plumbing Forum, Professional & DIY Advice 3 Inch copper waste pipe cracked and leaking. Feb 13, 2017
