Copper pipe through concrete foundation
Discussion in 'Plumbing Forum, Professional & DIY Advice' started by tedf, Feb 8, 2011.
  1. tedf
    tedf New Member
    Nov 23, 2009
    Seattle
    It is my understanding that a copper water supply line coming through a concrete foundation should not be in contact with the concrete. But what sort of sleeve or buffer should be used? I’ve seen black plumbing tape, closed-cell pipe insulation and spray foam sealant recommended. Is one of these the best choice - or something else?
  2. Basement_Lurker
    Basement_Lurker One who lurks
    Jun 21, 2007
    I smash things and demand money.
    Victoria, BC
    You need something rigid enough to stand up to the wet concrete. Your best/easiest bet is to wrap your risers in foam...they sell foam insulation tubes which would work well for this, or you could just cut pvc risers and shove them deep into the dirt to make your seal.
  4. hj
    Are you talking about the "foundation" or the "floor slab". They are two different situations and require different solutions, since a pipe through the foundation usually has to have provision to be sealed water tight.
  5. PlumbPowerHouse
    PlumbPowerHouse Plumber
    Dec 10, 2009
    South Carolina
    If going through the foundation, we have used pvc pipe to sleeve it. If coming through a slab, we have used foam and roof felt.
  6. hj
    Through the slab, we either use Armorflex insulation or the vinyl sleeving.
Similar Threads: Copper pipe
Plumbing Forum, Professional & DIY Advice Bending 3/8" chromed copper supply pipe to toilet Monday at 8:27 AM
Plumbing Forum, Professional & DIY Advice 3 Inch copper waste pipe cracked and leaking. Feb 13, 2017
Plumbing Forum, Professional & DIY Advice The beginning of a copper repipe Jan 29, 2017
Plumbing Forum, Professional & DIY Advice Help with Copper Pipe Support Jan 15, 2017
Plumbing Forum, Professional & DIY Advice Aligning Copper Pipe (Visual Included) Jan 9, 2017
