copper pipe straps, solder?
Discussion in 'Plumbing Forum, Professional & DIY Advice' started by northman, Aug 13, 2007.
  1. northman
    northman Member
    May 14, 2007
    Washington
    I noticed in a couple places the plumber that did work on my house soldered the copper pipe straps to the pipe, is this normally done? I had always just thought they screwed down and held the pipe with friction, never thought about soldering them.
    Greg
  2. Master Plumber Mark
    Master Plumber Mark Master Plumber
    Feb 6, 2005
    Sensitivity trainer...healey-feeley.....
    probably some old german plumber
    It is just the way the guy liked to work..
    it is certainly makes for a very solid job
    and perhaps it keeps the line from ever
    making knocking --creaking noises
    I see it all the time
    although I have wondered if it wont let
    a long run expand and contract properly
    best to let sleeping dogs lie
  4. cwhyu2
    cwhyu2 Consultant
    Aug 11, 2007
    Consultant
    Cincinnati OH
    I have sen this done before and have done it myself.
    But on a long run I wouldnt .As Mark said.
  5. GrumpyPlumber
    GrumpyPlumber Licensed Grump
    Jun 18, 2007
    Plumber, self employed
    Licensed Grump
    Soldering strap clips to copper pipe for reducing expansion noises is redundant.
    The straps move, as long as the screws on the clips are tight there's no creaking, not from the hanger at least.
  6. Dunbar Plumbing
    Dunbar Plumbing Master Plumber
    Apr 18, 2005
    Service Plumber, Outdoor Temperature Relief Owner
    There is a plumber in my area that has been using galvanized ductwork supports and soldering to copper.
    Everyone knows what's going to happen years down the road, it will eat a hole in that copper pipe.
    I understand the ease of those over cutting a piece a wood and banging 2 or 4 nails in but that is just improper workmanship.
    This same plumber is the same plumber that heats a staple to put a weep hole in a sump pump discharge to prevent air lock,
    same guy who hangs a ST-12 tank perpendicular from the water line and watch nearly 40 pounds of water make it bend down when it blows,
    Same guy that doesn't know how to wipe a solder joint down after completion to clean up the flux.
    He does it like he knows he ain't coming back. Gives me a job but should I care? Yes
    You're a professional, act like one.
  7. Furd
    Furd Engineer
    Jul 3, 2007
    Retired energy systems engineer
    Wet side of Washington State
    My plumbing is all suspended by copper-coated long U staples. Most of them were at one time soldered to the copper piping and most of them have since broken loose.
  8. construct30
    construct30 New Member
    Jun 16, 2007
    NorthWest PA
    If I strap a copper pipe to the joist, I like to use the plastic straps. I think the pipe has to be able to expand and contract. The plastic straps do it quieter. If only some of the straps were soldered then he was working by himself and just wanted to keep the pipe from moving while he worked.
    They do make copper coated hangers that look just like the duct hangers, I would never allow someone to solder metal to copper. Of course some of the cheap copper coated straps rust and we use them, probably just as bad. They just look better until we leave. That's why I switched to plastic straps. They also work on the PEX I use.
    mark
  9. got_nailed
    got_nailed DIY Senior Member
    Jan 11, 2006
    I have been using the pipe insulation and then using a bigger strap to hold them down. I only do this on long open runs. They can move all they want and will not bind as easy or make noise when they do it. The rest of the time I just use a standard copper strap.
    Part of the reason I started doing this is because of the hot water recalculation systems that everyone wants on there main water lines. I don’t use the pump method.
Similar Threads: copper pipe
Plumbing Forum, Professional & DIY Advice Bending 3/8" chromed copper supply pipe to toilet Monday at 8:27 AM
Plumbing Forum, Professional & DIY Advice 3 Inch copper waste pipe cracked and leaking. Feb 13, 2017
Plumbing Forum, Professional & DIY Advice The beginning of a copper repipe Jan 29, 2017
Plumbing Forum, Professional & DIY Advice Help with Copper Pipe Support Jan 15, 2017
Plumbing Forum, Professional & DIY Advice Aligning Copper Pipe (Visual Included) Jan 9, 2017
