copper pipe questions
Discussion in 'Irrigation / Sprinkler Forum' started by trae08, Sep 5, 2007.
  1. trae08
    trae08 New Member
    Sep 5, 2007
    hi im new here and i have a question. im gonna be working with copper and im wondering what is better to use? the copper epoxy or soldering the copper? the copper will hold about 300-400 psi
    didnt know where else to post this question so i hope this is the ok section for it.
  2. frenchie
    frenchie Jack of all trades
    Dec 30, 2006
    Caretaker
    Lord, I hope that's a typo.
  4. trae08
    trae08 New Member
    Sep 5, 2007
    lol umm no its not i dunno about 300-400 but it will go up to 200.
  5. geniescience
    geniescience Homeowner
    Nov 27, 2005
    ditto
    explain more, tell more, give more context. Something will be clearer after that.
  6. Gary Swart
    Gary Swart In the Trades
    Sep 1, 2004
    Yakima WA
    First, forget about the epoxy on copper. Solder it. But what in the world are you working on that will have 200 psi? If this is some kind of boiler, you should not be doing this yourself. If it's a home water system, there seems to me that there is no way you can have that much pressure. It would blow everything in the house about, especially the water heater and toilets.
  7. trae08
    trae08 New Member
    Sep 5, 2007
    o ok well here it is. im building a potato gun. an thx for the info.
  8. CHH
    CHH New Member
    May 25, 2007
    Denver, CO
    Well it is Sept and school has started again...
    The traditional potato gun is made from PVC. Much cheaper than copper and easier to work with.
    If you have to use copper then just solder it or use epoxy it really won't matter. If the darn thing blows up in your face then I will deny ever making this post.
  9. trae08
    trae08 New Member
    Sep 5, 2007
    yea i know there made from pvc and i have made a few pvc guns myself. go here an check out some of them www.spudfiles.com but im using copper cause its smaller then pvc and its going to fit in the stock on the new gun..
    and if it blows up im not the kinda person to come after you for saying use epoxy or solder it
  10. hj
    epoxy
    I would not trust epoxy at 100 psi, much less 200 psi. Solder the copper with 95/5 solder and make good joints. And use at least type "L" copper. By the time you get done, you might have been able to purchase an Uzi cheaper.
Similar Threads: copper pipe
Irrigation / Sprinkler Forum drip irrigation with 1/2" copper pipe Mar 28, 2009
Irrigation / Sprinkler Forum plan to cut the copper pipe Jul 24, 2008
Irrigation / Sprinkler Forum PVC - Copper Pipe Joint Jul 14, 2008
Irrigation / Sprinkler Forum Burst Pipes, can I make a transition from copper? May 12, 2008
Irrigation / Sprinkler Forum Need help to fix broken copper tubing Nov 7, 2015
