FlynHokie
Hello again all! I'm in the middle of remodeling my hallway bath - tore it down to stud walls, and installing new everything.
Cast Iron Kohler K-716 tub is inplace (what a pain in the rear!!) and drain plumbing run. Hot/cold water to pressure balance valve, and pipe run to shower head 90deg fitting and down to tub spout 90deg pipe.
The tub spout is a Grohe slide on with set screw. Question is, how far into the spout should the copper pipe run? See picture for reference - Should it a) run to the black gasket, b) run just past the gasket, c) run all the way to the front of the spout? If past the gasket (which makes sense to me - as that is probably a seal of sorts), then should I apply any lubricant to prevent damaging the gasket?)
I've left enough pipe hanging ther to do any of the options, and still have to install the Swanstone walls prior to hooking up the spout, so I at least planned for anything on the spout.
Thanks in advance!
FlynHokie
Thanks in advance!
FlynHokie
