copper pipe in masonry wall
Discussion in 'Plumbing Forum, Professional & DIY Advice' started by geothrm, Jan 26, 2009.
  1. geothrm
    geothrm New Member
    Jan 26, 2009
    My house is made of cinderblock and concrete. I need hot water in my utility room.
    I want to run 1/2 copper pipe from under my kitchen sink, thru the wall to the outside, along the outside wall to the back of the utility room, and thru the wall again. The outside run is about 18 feet long.
    A friend told me that I can use a circular saw with a masonry blade to cut a trench for the outside run. Then lay the pipe in the trench, and refill the trench.
    Does this sound feasible? What size saw do I need? Any special masonry blade? What should I use to refill the trench: concrete, mortar?
    So, I think I know how to do this, I just don't know the specifics. If I could get some assurance, before getting started, that I won't ruin my saw, or (worse) my house, that would be greatly appreciated.
    Geo.
  2. Master Plumber Mark
    Master Plumber Mark Master Plumber
    Feb 6, 2005
    Sensitivity trainer...healey-feeley.....
    yes it will work
    I dont know what it will do to your saw blade. or how many
    saw blades you will chew up....maybe you ought to rent a saw..
    I know it would be wise to put the copper pipe in
    some sort of protective sleeve through the wall and
    in the trench .before you cover it up...
    the black armaflex covering works best..
  4. geothrm
    geothrm New Member
    Jan 26, 2009
    Thanks Mark. I guess this is not really a plumbing question, so I'll switch to a masonry forum. But thanks for the tip on insulation, which I wouldn't have thought of.
    Geo.
  5. frenchie
    frenchie Jack of all trades
    Dec 30, 2006
    Caretaker
    Always wrap copper in insulation (compressible foam type sleeves are typical) where it contacts masonry. The pipe needs some play for expansion & contraction without rubbing against the masonry.
    I'm going to assume you're somewhere warm enough for pipe freezing not to be an issue...
  6. geothrm
    geothrm New Member
    Jan 26, 2009
    Yes, actually in Puerto Rico. I'm guessing the temp swing is rarely any greater than 60-95. May be enough to cause damage over the years?
  7. frenchie
    Dec 30, 2006
    Caretaker
    The pipes will still move from hot/cold water going through them, so you still need to sleeve them in something compressible.
    You might have a harder time finding the foam insulation sleeves I was talking about, down there, than up here, though!
    ... just wrap the pipe in something that will create some space around it when you re-pack the trench.
  8. geothrm
    geothrm New Member
    Jan 26, 2009
    OK, thanks frenchie.
  9. daz49
    daz49 New Member
    Jan 29, 2009
    you may want to find out what the chemicals in the concrete will do to the copper overtime
  10. geothrm
    geothrm New Member
    Jan 26, 2009
    It appears there are no chemical reactions between copper and concrete that would prevent this.
  11. Terry
    Aug 17, 2004
    Copper and concrete are always a bad combination.
    Code here requires that the copper be protected from the concrete.
  12. geothrm
    geothrm New Member
    Jan 26, 2009
    And the insulation should take care of that.
  13. SewerRatz
    SewerRatz Illinois Licensed Plumber
    Nov 20, 2008
    Chicago Illinois Licensed Plumber
    Chicago, IL
Similar Threads: copper pipe
Plumbing Forum, Professional & DIY Advice Bending 3/8" chromed copper supply pipe to toilet Monday at 8:27 AM
Plumbing Forum, Professional & DIY Advice 3 Inch copper waste pipe cracked and leaking. Feb 13, 2017
Plumbing Forum, Professional & DIY Advice The beginning of a copper repipe Jan 29, 2017
Plumbing Forum, Professional & DIY Advice Help with Copper Pipe Support Jan 15, 2017
Plumbing Forum, Professional & DIY Advice Aligning Copper Pipe (Visual Included) Jan 9, 2017
