Copper Joints under Slab
Discussion in 'Plumbing Forum, Professional & DIY Advice' started by DME, Feb 7, 2007.
  1. DME
    DME New Member
    Feb 2, 2007
    I know it's not preferred that you have a joint under a slab. But, if there is no way to avoid it what is the most reliable method. I am considering going with flare joints. It's 1/2 copper lines. Any thoughts?
  2. srdenny
    srdenny Plumbing Contractor
    Sep 11, 2004
    Plumbing Contractor
    SF Peninsula
    Silver soldering is a code approved, below slab method of joining copper tube and fittings.
  4. Randyj
    Randyj Master Plumber
    Nov 25, 2006
    Alabama
    I don't remember what the code is on flared joints under slab. Myself, I wouldn't do it because there will never be access to take it apart even if you wanted to. As for any kind of metal line under slab... my experience says that it needs to be protected from the chemicals of the concrete and should be in a plastic sleeve to protect the metal.
  5. kordts
    kordts In the Trades
    Oct 15, 2005
    industrial service plumbing foreman
    exurban Chicago
    Most codes let you either flare or braze under slabs.
  6. hj
    joints
    I always perfer flare over brazing, if the fittings are available. Brazing is "destructive" in that it removes the temper from the fittings, making them "flexible" and subject to cracking and breaking.
  7. Racer814
    Racer814 New Member
    Dec 24, 2006
    silver solder.
  8. hj
    silver
    Silver solder also requires a red hot joint, which also detempers the fitting.
  9. Randyj
    Nov 25, 2006
    Alabama
    Interesting... if using appropriate materials and properly making the weld and protecting it then it should be a moot argument when the concrete is poured...but at least now I know.
    Using the "proper material and method" only means it was done to the least highest standard. The "proper" steel gas line, is a very poor material to bury in the ground, but an inspector will approve the installation. I have had 1/2" lines silver soldered to a 2 x 1/2 tee, and the branch of the tee broke off because the fitting's "hardness"/temper had been destroyed by making the joint.
Similar Threads: Copper Joints
Plumbing Forum, Professional & DIY Advice Corrosion at copper joints. Why?? May 24, 2010
Plumbing Forum, Professional & DIY Advice Repairing Copper Sweat Joints Jan 1, 2007
Plumbing Forum, Professional & DIY Advice pre soldered copper joints Jan 16, 2006
Plumbing Forum, Professional & DIY Advice Copper joints..????????? Jan 27, 2005
Plumbing Forum, Professional & DIY Advice Bending 3/8" chromed copper supply pipe to toilet Monday at 8:27 AM
