Converting Surface Mount Panel to Recessed?
Discussion in 'Electrical Forum discussion & Blog' started by Nate R, Nov 16, 2009.
  1. Nate R
    Nate R Member
    Jan 11, 2007
    I perform R&D testiing at small engine manuf.
    Milwaukee, WI
    My main panel is currently surface-mounted to an interior wall in our back porch with the feed from the meter coming in through the backside.
    Can I add lumber over the existing wall, re-run the wiring through the new lumber, while keeping the box in place, essentially making what was a surface mount box a recessed box? I'd like to be able to hide what would be exposed wiring in a wall, as the back porch area will eventually be visible from the kitchen.
    What code sections do I need to be looking at that deal with this specifically?
  2. jbfan74
    jbfan74 Electrical Contractor
    Jun 14, 2007
    Newnan, GA
    Not a problem.
  4. Alectrician
    Alectrician DIY Senior Member
    Jun 15, 2007
    As long as the panel is within 1/4" of the finished drywall you are good.
    Also, it would be easier to notch the lumber around the existing wiring.
  5. Nate R
    Nate R Member
    Jan 11, 2007
    Milwaukee, WI
    Duh, didn't think of notching it! It's only there to hold up wallboard, so it doesn't need much.
    Thanks for the help!:D
Similar Threads: Converting Surface
Electrical Forum discussion & Blog Converting 2 Way switch to add a Timer Jan 11, 2015
Electrical Forum discussion & Blog Converting Two Recessed Lights on a Single Switched Leg Jun 16, 2014
Electrical Forum discussion & Blog converting pool light to LED, need transformer. Jun 8, 2014
Electrical Forum discussion & Blog Converting from larger to smaller wire gauge May 15, 2011
Electrical Forum discussion & Blog Converting Light Fixture Box To Powered Outlet Jan 31, 2011
