Converting single bathroom sink to double sinks
Discussion in 'Plumbing Forum, Professional & DIY Advice' started by maxxfusion, Mar 26, 2011.
  1. maxxfusion
    maxxfusion New Member
    Mar 26, 2011
    Cleveland, Ohio
    I am in the process of remodelling my bathroom. I have a 72" vanitiy with a single sink. I figured since I have the space double sinks would be really nice to have especially with kids. I made this decision late in my remodel project. I looked under the cabinet to check things out and found out that at one time there was double sinks there. So all the copper is in place. Here is my issue. I went to Lowes today and bought some ABS. I can not find the double fixture tee anywhere. I came home and googled the part. I came across the tee at Grainger but its 2 x 1 1/2 x 1 1/2 x 1 1/2. The abs pipe that runs upstairs is 1 1/2.
    So my question is does the double fixture tee i need exist in all 1 1/2? I am assuming i will have to order this online.
    Any help would be greatly appreciated.
  2. maxxfusion
    Mar 26, 2011
    Cleveland, Ohio
    I just found a double sanitary tee in all 1 1/2. Not sure if I can use that?
  4. Terry
    Aug 17, 2004
    The 1.5 double santee will be a bear to snake. It would need a cleanout on the vent to clear the center.
    There are also ways to run it using a wye and two santees that would force the snake downhill instead of over and across to the other lav location.
    If I had 1.5" pipe, I wouldn't even bother with a cross, but instead wye off and have opposing santees to to separate trap arms and then revent at 42"
    I know that are come countries that will do it, but they must not have ever done service work. I would love to watch them try to get the snake to drop down the vertical.
    [​IMG]
    Just found this picture
  5. dlarrivee
    dlarrivee New Member
    Jun 28, 2009
    Foam/Fireproofing/Acoustical
    Canada
    I searched this forum to find this picture from a thread created last year...
    [​IMG]
  6. maxxfusion
    Mar 26, 2011
    Cleveland, Ohio
    My issue is i dont have the pipes exposed. I would need to rip out drywall to do this.
    Can i use this and some 45 degree elbows?
    [​IMG]
  7. dlarrivee
    Jun 28, 2009
    Canada
    How would that be any better than the double santee.
    Look at what Terry posted, do you a see a double fitting of any type there?
  8. Terry
    Aug 17, 2004
    No.
    That type of fitting would need to have vents on each arm. That fitting with a 45 creates an S trap.
  9. maxxfusion
    Mar 26, 2011
    Cleveland, Ohio
    How do they do it in new homes?
  10. Terry
    Aug 17, 2004
    2 x 1.5 x 1.5 1.5 fixture cross.
    [​IMG]
    [​IMG]
    Double Lav
  11. maxxfusion
    Mar 26, 2011
    Cleveland, Ohio
    So if I could find a 1.5 x 1.5 x 1.5 x 1.5 fixture cross I would be ok? I have looked a bit online and can only find the 2 x 1.5 x 1.5 1.5 fixture cross. Since I had the double sinks at one time and only have 1.5 pipe run to the bathroom can I just use a reducer to go from the 2 pipe to the existing 1.5?
  12. Terry
    Aug 17, 2004
    You can only increase pipe size as you drop down.
    You can't decrease.
  13. maxxfusion
    Mar 26, 2011
    Cleveland, Ohio
  14. dlarrivee
    Jun 28, 2009
    Canada
    You certainly cannot...
    Basic rule of plumbing, you'd be creating a funnel...
  15. maxxfusion
    Mar 26, 2011
    Cleveland, Ohio
    Ok thanks guys. I guess I will be removing some drywall and going off of Terrys pic he posted.
  16. SacCity
    SacCity In the Trades
    Mar 14, 2011
    Sacramento, CA
    So tell me why you can not use two (2) San Tee's facing opposite directions one three inches lower than the other.
    It would result in about a 3" difference in heights for the two P-Traps but that should not be an issue, and would have a short section of a wet vent.
    Michael
  17. dlarrivee
    Jun 28, 2009
    Canada
    Besides the venting issue, would you honestly be proud to have a tail piece under one sink that is 4" longer than the other? I would view that as a mistake as a prospective buyer of the home...
  18. Terry
    Aug 17, 2004
    The minimum wet vent is a 2" pipe.
    To keep the venting working right, I would still separately vent them.
  19. SacCity
    Mar 14, 2011
    Sacramento, CA
    Minimum wet vent is 2",
    Well I screwed that one up yesterday on a repair.
    Thanks for correcting me.
    Michael
  20. maxxfusion
    Mar 26, 2011
    Cleveland, Ohio
    I am going to get my parts today. So just to confirm to do the method Terry recommended i will need 4 san tees and 2 45s? I already got the 2 90s.
    Also I should measure up 42" from the first san tee to connect the second san tee for the venting?
  21. dlarrivee
    Jun 28, 2009
    Canada
    Incorrect, the offset of the stack is created with wyes and 45s, not santees... the santees are where the trap arm ties in...
    You need 2 wyes, 2 santees, 2 45s (street in his photo)... and pipe obviously...
    You already have 2 90s, but are they long radius or vent ells?
    I'd be installing a clean out below the lower wye myself.
Similar Threads: Converting single
Plumbing Forum, Professional & DIY Advice Converting basement single vanity bathroom into double vanity. Have questions Dec 30, 2015
Plumbing Forum, Professional & DIY Advice Converting Single Sink to Double Sink with water line for humidifier Apr 28, 2014
Plumbing Forum, Professional & DIY Advice Converting single sink vanity to double vanity Nov 20, 2011
Plumbing Forum, Professional & DIY Advice Which drain to use when converting from double to single sink Sep 5, 2009
Plumbing Forum, Professional & DIY Advice Converting single vanity into double Dec 29, 2008
