Converting Light Fixture Box To Powered Outlet
Discussion in 'Electrical Forum discussion & Blog' started by Kiko, Jan 31, 2011.
  1. Kiko
    Kiko Member
    Jul 20, 2009
    Royal Oak, Michigan
    What's the most elegant way of doing this, without replacing the round light box with a standard receptacle box? It's in a living room, so I really don't want to use one of those ugly, gray metal "work box" receptacle covers that the hardware stores recommend. After wiring in the receptacle, can I just screw the receptacle into the existing box and then screw a nice 5" round decorative outlet cover to the receptacle?
  2. jadnashua
    If you can find a decorative round cover, it should be fine.
  4. hj
    You will probably need a "round grey work box plate" to adapt to the receptacle. Once that is done, you use any wall plate that covers the opening over the receptacle.
  5. Kiko
    Kiko Member
    Jul 20, 2009
    Royal Oak, Michigan
    That's exactly what I ended up doing. Without the round gray workbox adapter, the receptacle doesn't screw in properly to the round light box. Then I searched all over for a very oversized single-gang outlet cover in white. I found one at an old, Ma and Pa hardware store near me.
Similar Threads: Converting Light
Electrical Forum discussion & Blog Converting Two Recessed Lights on a Single Switched Leg Jun 16, 2014
Electrical Forum discussion & Blog converting pool light to LED, need transformer. Jun 8, 2014
Electrical Forum discussion & Blog Converting 2 Way switch to add a Timer Jan 11, 2015
Electrical Forum discussion & Blog Converting from larger to smaller wire gauge May 15, 2011
Electrical Forum discussion & Blog converting air compressor 220v motor to 110? Jul 6, 2010
