Converting deck-mount faucet to wall-mount?
Discussion in 'Plumbing Forum, Professional & DIY Advice, Tips & ' started by David95966, Sep 23, 2013.
  1. David95966
    David95966 New Member
    13
    Oroville, CA
    I would like to convert a deck-mount faucet to wall-mount to make cleaning easier and avoid accumulation of water. At first I assumed I would have to reroute plumbing into the wall, but then saw this site which runs the plumbing through the backsplash. This fixture is out of my price range.
    How would I use off-the-shelf hardware to achieve the same result as this fixture?
  2. dj2
    dj2 Member
    399
    California
    Less than brilliant idea.
    1. The body is held by one nut. In time the faucet will be out of level and it will get loose.
    2. The wooden supply lines cover back splash will deteriorate with leaks.
    3. To change supply lines, you will need to detach the whole cabinet in order to gain access.
    If you absolutely have to have a wall mount, stick to a traditional wall mount faucet.
    Wall mount faucets used to be popular, but they disappeared in the last 20-25 years. Go to any faucet shop and you'll see dozens of counter mount faucets available and only one or two wall mount available.
  3. hj
    26,285
    quote; How would I use off-the-shelf hardware to achieve the same result as this fixture?
    You won't. Most of the cost of a faucet is for the "trim" pieces, and they are different for a wall mount faucet than a deck mount one, particularly the spout design. You can mount a deck mount faucet in the wall, or vice versa. The handles would work either way, but the spouts would NOT.
  4. David95966
    13
    Oroville, CA
    Thank you both for your replies.
Similar Threads: Converting deck-mount
Plumbing Forum, Professional & DIY Advice, Tips & Converting a wall-mounted faucet to a "back splash faucet" for a farmhouse sink May 6, 2014
Plumbing Forum, Professional & DIY Advice, Tips & Converting Single Sink to Double Sink with water line for humidifier Apr 28, 2014
Plumbing Forum, Professional & DIY Advice, Tips & Converting two drains to one in kitchen sink Nov 5, 2013
Plumbing Forum, Professional & DIY Advice, Tips & Converting a vented (somewhat) S trap to a p -trap? Aug 14, 2013
Plumbing Forum, Professional & DIY Advice, Tips & Converting 3/8"OD x 3/8"OD supply line to 3/8"ODx1/2"IPS Jul 29, 2013
