Convert Slab Shower Stall to Level Floor for Steam Shower Unit
Discussion in 'Shower & Bathtub Forum & Blog' started by Saitek, Feb 13, 2010.
  1. Saitek
    Saitek New Member
    Feb 13, 2010
    Florida, USA
    I am renovating a bathroom that is built on a slab foundation. I want to install a stand alone steam shower that requires a level floor to set the unit on. I want to use the space where the current built in shower is located. The plan is to use the existing hot/cold supply lines and drain.
    The existing shower was build into the slab foundation. That is, a rectangular hole was left when they poured the foundation. Then a cement bed was created below the slab level and was tiled over forming the shower pan. I want to fill in the existing shower pan so it is level with the slab foundation. I will install new flooring over the entire bathroom. The stand along steam shower comes with a build in pan and sits on the floor. Kind of like a piece of furniture.
    What is the best way to make the area level? Should I frame in the old shower pan area and cover with cement board or should I pour cement into the area so just the drain pipe is above slab level.
    Hope this makes sense. Thanks for any help.
Similar Threads: Convert Slab
Shower & Bathtub Forum & Blog Converting A laundry closet to a wet room Feb 22, 2015
Shower & Bathtub Forum & Blog Converting From Spout Diverter to Valve Diverter Jan 23, 2015
Shower & Bathtub Forum & Blog Convert copper pipes from tub/shower to shower? Oct 15, 2014
Shower & Bathtub Forum & Blog Basement tile shower (drain) install - converting existing floor drain Mar 13, 2014
Shower & Bathtub Forum & Blog Converting an old Adobe Wall into a new tiled shower wall - How to plan step by step Jun 4, 2013
