Convert Shower to soaker bath
Discussion in 'Shower & Bathtub Forum & Blog' started by wsmithe, Jan 22, 2007.
  1. wsmithe
    wsmithe New Member
    Jan 22, 2007
    I have a neo angle shower pan, 36" x 36". I'd like to extend the sides so that I can use it as a deep soaker bath or a shower. The pan is fiberglass. The sides must be strong enough to hold water and to support the weight of a person climbing into the shower. Any ideas?
  2. Bob NH
    Bob NH In the Trades
    Oct 20, 2005
    New Hampshire
    Yes. Replace it with a real bathtub.
    You can either do that now, or after you wreck some things below with leaks from your extensions.
    A 36 x 36 bathtub would be wretchedly small for a soaker bathtub except for a child or a very small person.
  4. wsmithe
    wsmithe New Member
    Jan 22, 2007
    soaker tub
    I neither have the budget nor the room for a bath. Soaker tubs of this size exist in Europe and Japan. They are wonderful if deep enough. One sits upright on a little stool. I don't want to demolish my bathroom. It was only recently installed with marble tiles and beautiful fixtures. The shower enclosure is all glass and, for a 6'x6' bathroom, I believe I've made the best of this tiny area which has a toilet to one side of the corner shower and a pedestal sink on the other. However, I long for a soak. After my stay in Japan a few years ago, I was determined to duplicate their soaker baths which range from fiberglass molded shapes to artisitic carved stone and wood. I cannot afford to import this and am hoping for a solution using my existing circumstances. Would acquariam makers be a way to go?
  5. geniescience
    geniescience Homeowner
    Nov 27, 2005
    ditto
    right! and beyond your skill level
    smithe
    you are right that a deep soaker tub is good, no matter how small. Bob is also right to tell you to buy a tub. Based on your first post (description of problem), you don't appear able to build a custom tub. Your description is missing so much, I'm too lazy to tell you what it would need for me to believe you might be the right candidate to correspond with about buiding a custom tub.
    david
  6. hj
    tub
    The time to have considered this was before the room was remodeled. Now it would be virtually impossible to extend the base of the shower and make any kind of strong permanent watertight extension to them.
  7. TedL
    TedL New Member
    Sep 17, 2006
    NY Capital District
    And then there's the problem of climbing in/out over the 3-4 foot high sidewall.....
  8. wsmithe
    wsmithe New Member
    Jan 22, 2007
    soaker tup
    Thank you for all your input.
Similar Threads: Convert Shower
Shower & Bathtub Forum & Blog Converting handles and/or valves on old pfister price bath/shower faucet Apr 17, 2017
Shower & Bathtub Forum & Blog Convert Roman tub to permanent shower Jul 5, 2015
Shower & Bathtub Forum & Blog Convert copper pipes from tub/shower to shower? Oct 15, 2014
Shower & Bathtub Forum & Blog Basement tile shower (drain) install - converting existing floor drain Mar 13, 2014
Shower & Bathtub Forum & Blog Converting an old Adobe Wall into a new tiled shower wall - How to plan step by step Jun 4, 2013
