convert NEMA 6-20R outlet to standard 110 outlet?
Discussion in 'Electrical Forum discussion & Blog' started by cham33, Aug 15, 2010.
  1. cham33
    cham33 New Member
    Aug 15, 2010
    TN
    I have a NEMA 6-20R outlet that went to an old air conditioner. The new AC uses a regular 110 outlet - 3 prong. So basically I have hot, hot, ground but I need hot, neutral, ground. What is the easiest way to go about doing this? Any help would be greatly appreciated. First time poster so go easy on me ;)
  2. jimbo
    jimbo Plumber
    San Diego, CA
    Electrically, it would work if at the panel end you took one leg of the 240 and repurposed it to the neutral bus. You would tape both ends with white tape to identify it as a neutral. We will wait for one of our electricians to tell us if this is allowd by codes.
  4. cham33
    cham33 New Member
    Aug 15, 2010
    TN
    Thanks! As of right now it has a hot that is white (not properly marked as hot). I inherited this home recently so it wasn't my doing. The house is old and has a fuse box, it has 2-30amp "Edison base" fuses for this circuit. I also found two 5–15R's outside under a deck, just plain old indoor rated receptacles and they were hot so I removed the fuse until I can replace them. Apparently such practices are common in this rural area of TN so I take nothing as a given.
Similar Threads: convert NEMA
Electrical Forum discussion & Blog Convert outlet to hardwire Nov 16, 2016
Electrical Forum discussion & Blog Converting 2 Way switch to add a Timer Jan 11, 2015
Electrical Forum discussion & Blog Converting Two Recessed Lights on a Single Switched Leg Jun 16, 2014
Electrical Forum discussion & Blog converting pool light to LED, need transformer. Jun 8, 2014
Electrical Forum discussion & Blog Cconvert 2 gang switch to 3 gang switch Jan 5, 2012
