Control flow and temp?
Discussion in 'Shower & Bathtub Forum & Blog' started by Bex, Dec 9, 2005.
  1. Bex
    Bex New Member
    Dec 9, 2005
    I am looking for shower faucets that allow you to control both the flow and the temperature. Seems like with so many now you get to choose the temp and it comes out with the same force no matter what. Anyone know what brand/model I should look at?
  2. Bob NH
    Bob NH In the Trades
    Oct 20, 2005
    New Hampshire
    Check Moen
    I have two Moen controls that were installed in '65 that do it. Flow is controlled by how far you pull the knob out toward you. Temperature is controlled by rotating the handle.
  4. jadnashua
    They are out there, I have one made by Grohe; I'm sure other companies make them as well. The particular one I have is a temperature-controlled valve (as opposed to a pressure balance valve). It may also have some pressure balance functions in it. One or the other is required in replacement/new construction to help prevent scalding hazards if something like someone flushing a toilet or other water use changes the amount of hot verses cold water available.
    On the one I have, there are two knobs - one allows you to set the desired temperature (it then adjusts the user set flow to make the output the set temperature) and the other sets the flow.
    This is not absolute, but the temp controlled valves probably all do what you want, while only some of the pressure balance ones do. My unprofessional opinion.
  5. jimbo
    jimbo Plumber
    Delta has several models in the 1700 series which have separate volume and temp controls. They are scald guard as well.
Similar Threads: Control flow
Shower & Bathtub Forum & Blog Whatever Happened To Integrated Tub/Shower Temp/Flow Controls? Jul 19, 2012
Shower & Bathtub Forum & Blog Variable flow volume control with a 2.5 GPM head Jun 29, 2011
Shower & Bathtub Forum & Blog AquaSource Shower - How Does 'Flow Control' Cartridge Gear Inside Handle Adjust? Apr 25, 2010
Shower & Bathtub Forum & Blog Mixette Shower Control- low flow Jul 14, 2007
Shower & Bathtub Forum & Blog Shower leak from temperature control Nov 4, 2016
