control box
Discussion in 'Pumps and Tanks Well Forum & Blog. Water is life.' started by 85ray, Mar 29, 2013.
  1. 85ray
    85ray New Member
    Jan 17, 2013
    Seattle, Washington
    I just had pump and pressure tank installed at my new property now I need to wire breaker the deluxe 3hp control box and pressure switch I am confused the pump directions say different from control box. Its a Gould's 3hp pump and Gould's or Franklin deluxe control box. I see where the red yellow black go from the well my question is from my 240v breaker do I run those wires into the control box? Then from the control box the sw and l1 go to the pressure switch plus the ground. Is that right? There will be two empty slots on the switch
  2. LLigetfa
    Feb 6, 2011
    Information Technology
    NW Ontario, Canada
    L1 & L2 from breaker to the switch. M1 & M2 from switch to control box.
  4. 85ray
    85ray New Member
    Jan 17, 2013
    Seattle, Washington
    On the control box I have sw,L1,L2,r,y,b that's it I might have the colors wrong I don't have box in front of me and I didn't see any markings on pressure switch
  5. LLigetfa
    Feb 6, 2011
    NW Ontario, Canada
    The switch should have four screws for four wires and two pairs of contacts. One wire from the breaker L1 goes to one side of a contact. From there it goes to the motor M1 from the other side of the same contact if no control box is used, or to the L1 of the control box. Repeat for L2/M2/L2.
  6. LLigetfa
    Feb 6, 2011
    NW Ontario, Canada
    Here is a schematic from the Goulds service manual.
  7. 85ray
    85ray New Member
    Jan 17, 2013
    Seattle, Washington
    What is the SW contact in my control box
  8. LLigetfa
    Feb 6, 2011
    NW Ontario, Canada
    Never heard of it. What does the manual say it is? Is it one contact or a pair of contacts?
  9. 85ray
    85ray New Member
    Jan 17, 2013
    Seattle, Washington
    The well guys left it there wasent a manual just a diagram. Its a deluxe 3hp controlcontrol box with a few difernt things inside but 6 connections
  10. LLigetfa
    Feb 6, 2011
    NW Ontario, Canada
  11. craigpump
    craigpump Well-Known Member
    Apr 12, 2012
    Self employed water system tech
    I don't install a lot of these deluxe boxes, but if memory serves me right you only need to use one side of the pressure switch to control the pump with the deluxe box.
  12. 85ray
    85ray New Member
    Jan 17, 2013
    Seattle, Washington
    That's what I have. so if I hook the control box up like what the diagram says ill be good? The SW goes to the load contact in the pressure swich and L2 goes to the line
  13. LLigetfa
    Feb 6, 2011
    NW Ontario, Canada
    Yes as shown in the schematic.
  14. 85ray
    85ray New Member
    Jan 17, 2013
    Seattle, Washington
    The diagram dose not exactly show where they go on the pressure switch
  15. VAWellDriller
    VAWellDriller Member
    Sep 8, 2012
    Mud rotary well driller, pump installer
    Richmond, VA
    Either set of contacts....doesn't matter. use either the two on left or two on right as a pair.
  16. 85ray
    85ray New Member
    Jan 17, 2013
    Seattle, Washington
    Thanks I am going to wire it up tonight
  17. valveman
    Mar 15, 2006
    Pump Controls Technician
    Lubbock, Texas
    L1 and L2 from the breaker straight to the L1 and L2 in the control box. Then you can use two wires and a ground as small as #18 to go from L2 and SW in the control box to one side of the pressure switch. If the points ever go bad, you can switch the wires and use the other side.
  18. 85ray
    85ray New Member
    Jan 17, 2013
    Seattle, Washington
    Thanks vavleman I thought I had to run bigger wire to the pressure switch after breakfast here I will wire that part up thanks for everyones help
Similar Threads: control
Pumps and Tanks Well Forum & Blog. Water is life. Have a F&W submersible pump seems to have stopped, replaced QB control box Jan 30, 2017
Pumps and Tanks Well Forum & Blog. Water is life. Confused about pumptec and control box Nov 27, 2016
Pumps and Tanks Well Forum & Blog. Water is life. Franklin Well Control Box Overload Trips Oct 19, 2016
Pumps and Tanks Well Forum & Blog. Water is life. Connected 115v pump with 230v control box Jun 27, 2016
Pumps and Tanks Well Forum & Blog. Water is life. Well Pump System Control Issue Jun 12, 2016
