Contractor installed wrong tankless water heater unit...
Discussion in 'Tankless Water Heater Forum' started by Terminum, Jan 27, 2014.
  1. Terminum
    Terminum New Member
    Jan 27, 2014
    Florida
    We had a Rinnai tankless water heater installed about a month ago; now the hot water occasionally does not work for hours at a time. The local dealer who installed it came out to do an inspection. Long story short, they installed the "wrong unit" (their words).
    The guy was using a lot of technical jargon, but as far as I can gather, instead of installing the correct unit they are just going to replace the regulator. He said that this one was only meant for 11 (unspecified units of pressure) and our lines are running at 13 (unspecified units of pressure) or something like that. This is causing the whole system to shut off regularly. This is what he said anyway.
    Is just replacing the regulator of a "wrong unit" a common practice? We paid full price for this (which he says is a comparable unit) but my concern is they are just doing a patch job and this could cause problems down the road. I cannot find any information about this online, and I have no idea what the heck is going on. Any advice is greatly appreciated.
  2. Reach4
    Reach4 Well-Known Member
    Sep 25, 2013
    Is that Propane? If so, it sounds reasonable to me.
  4. Terminum
    Terminum New Member
    Jan 27, 2014
    Florida
    Thanks for the fast response. It is natural gas. Sorry, I forgot to specify that.
  5. Reach4
    Sep 25, 2013
    In that case, I don't have a guess as to what the 11 or 13 would refer to. Residential natural gas pressure is a 4 to 6 inch water column (about 0.2 PSI).
    Will they extend the warranty to start once things are right?
  6. Terminum
    Terminum New Member
    Jan 27, 2014
    Florida
    Thanks, I will ask them about the warranty. The fact that you are not immediately throwing up red flags makes me feel a little better though.
  7. Reach4
    Sep 25, 2013
    I am not a pro, so don't take my thought as authoritative. You could ask more specifically what the change is, and you might check with the manufacturer as to whether that cure is proper.
Similar Threads: Contractor installed
Tankless Water Heater Forum New tankless installed....this can't be normal. Apr 6, 2011
Tankless Water Heater Forum Noritz tankless water heater - installed correctly??? Mar 12, 2011
Tankless Water Heater Forum Getting gas line reinstalled Jul 8, 2010
Tankless Water Heater Forum Noritz NR98-OD just installed Mar 29, 2010
