Keith Anderson
A contractor I had installing a 2500 gal storage tank disappeared on me so I am trying to finish it up myself. The tank is in and lines are run to my well house. I have a submersible pump (2hp I think) set at about 400' going through a pressure tank and to the house which is 200' away and about 50' rise in elevation (plus it's a 2 story house). The contractor provided a F&W CJ101 pump, a CSV125 valve, a check valve, a Pumptec and the float switch that is already installed in the tank. From the reading I have been doing, the Pumptec will be set up to protect the submersible pump and I assume that the CSV is to protect the booster pump. My question is how should the system be plumbed up. Can someone provide me with a diagram showing how I should plumb everything together? Any help would be greatly appreciated.
