Constantly Running Tankless Toilet
Discussion in 'Toilet Forum discussions' started by stick_face, Jul 28, 2007.
  1. stick_face
    stick_face New Member
    Jul 28, 2007
    I didn't see anything else out there...
    I've had a running wallmount toilet for the last 2 hours. Jiggling the handle does not help. I have no ideas what to do. As the title indicates, there is no tank. It's a commercial style (don't know the proper terminology) toilet that has plumbing coming out of the wall. And the only known shutoff turns off the water for the entire building. The toilet bowl is fortunately not filling up, but there is a constant flow of water (rush of water is more appropriate).
    Can I do something with the screws/nut to "reset" it? What can I do?
    Any help is appreciated!
  2. markts30
    markts30 Commercial Plumber
    Sep 25, 2006
    Commercial Plumber
    Phoenix, AZ
    Is it a chromed flush valve mounted above the toilet?
    If so, the shutoff valve should be on the chromed anglestop that you see on the feed pipe before the actual flush valve...
    Remove the anti-tamper cover on the end of the stop and you can use a standard screwdriver to shut the water off...
    Once you do that, you can have a plumber come in to repair the valve - it is probably just a bad diaphragm or seal in the valve itself...
  4. stick_face
    Jul 28, 2007
    Perfect. Thank you.
Similar Threads: Constantly Running
Toilet Forum discussions toto guinevere running constantly, help! Jan 24, 2011
Toilet Forum discussions case toilet running constantly Jul 22, 2005
Toilet Forum discussions Toto Neorest 600 water constantly trickles into bowl while in use Aug 1, 2016
Toilet Forum discussions Toilet constantly filling slowly Aug 10, 2010
Toilet Forum discussions Toto is constantly filling, not quite sure how to fix Aug 4, 2010
