Constant pressure
Discussion in 'Pumps and Tanks Well Forum & Blog. Water is life.' started by Cass, Jan 3, 2006.
  1. Cass
    Cass Plumber
    Nov 12, 2005
    I work on maybe 5-10 wells a year. Mostly replacing pumps, tanks, or switches. The up and down pressure is the biggest complaint I hear. The addition of a pressure regulator in the other thread got me to thinking. Are there any drawbacks to doing this? If I were to add a regulator and set the pressure at 50# with the tank and switch set at 50-70 are there any problems that this would cause. I know an older tank bladder might burst by changing the pressure. How about a shorter pump life? Talk to me.
  2. speedbump
    speedbump New Member
    Jul 15, 2005
    Water well and pump tech.
    Riverview, Fl.
    Rather than spending the money for constant pressure pumps, you can use the Smart Tee or the Cycle stop valve and do about the same thing. You can use a smaller tank just like with the constant pressure units but save a bunch of money in the process.
    You can turn the pump on at 60 and off at 80 with the Smart tee set at 70 and have 70 psi constant pressure as the pump runs. Same thing with the constant pressure pumps. The pressure is only constant when the pump is running.
    A pressure regulating valve is basically what the Smart Tee is.
    bob...
  4. rshackleford
    rshackleford New Member
    Oct 18, 2005
    Eastern Montana (The Bakken)
    We have been installing constant pressure systems for sis or seven years now and are really happy with them. They work really nice when a customer has a high producing well. All of our customers are quite happy. On an installation from scratch the cp system in only $200-$300 more than a standard system with a large tank. I think that once you add in the regulator valve and motor protection to match a cp unit you will be almost even money. Also, if you installed a small tank and the pressure valve your pump would start and stop with every water demand. This happens with a cp unit, but the motor is ramped to start and stop. This soft start makes a big difference in the heat buildup and life of a motor.
    Oh, and don't forget about the troubleshooting codes provided by the system. These are a pretty good added bonus. You can work with your customer over the phone. We have had three cp units fail. One an electrician drilled a hole through, one was flooded in a well pit, and another was hit by lightning.
    Also, when these units first came out we had a pretty big fight with radio interference. We learned a few things, the manufacture learned a few things, and now this is a non issue.
    I wonder about some of the bad water out there. Are these pressure regulator valves prone to plugging with sediment or rust bacteria?
  5. speedbump
    Jul 15, 2005
    Riverview, Fl.
    When I was looking at them, they were pretty pricie. Maybe they have come down.
    I could not get any interest in them at all in my area, so I gave up and went with the Smart Tee.
    I'm sure with nasty water the pumps can have problems as easily as the Smart tee.
    Being near Tampa Florida, the lightning capital of the world, electronic pumps aren't the best choice. Just like filter heads. I avoid the electronic heads and stay with simple electric motor driven heads with water meter driven auto regeneration.
    bob...
  6. rshackleford
    Oct 18, 2005
    you make a good point.
    the fe unit uses a standard motor.
    the grundfos unit uses a motor with a computer chip. you cannot use an ohm meter to check out this motor. they cost more money too.
    you may want to reconsider the fe unit.
  7. Pumpman
    Pumpman Pump Sales
    Apr 12, 2005
    Owner - R.L. Peeks Pump Sales
    So. Cal
    We're getting more and more calls for constant pressure, and we're using the VFD systems. As I've stated before, we have very few wells in this area, so we use VFD on jetpumps and irrigation centrifugals. One of our suppliers thought I was nuts to use one on a jetpump, but after he saw it work, he changed his mind.
    There's alot of building going on in this area, and the upscale homes have higher pressure requirements with the full body showers, etc. We're not limited by well capacity, since water is delivered via canal, so we can meet most any capacity and pressure requirements.
    I'm also looking at the possibility of using a submersible like the Grundfos SQE in a cistern setting.
    Ron
Similar Threads: Constant pressure
Pumps and Tanks Well Forum & Blog. Water is life. Well Pump Pressure Switch constantly cycling on and off Mar 9, 2017
Pumps and Tanks Well Forum & Blog. Water is life. Goulds Balanced flow constant pressure pump May 20, 2016
Pumps and Tanks Well Forum & Blog. Water is life. F AND W comander pro constant pressure problem Sep 26, 2015
Pumps and Tanks Well Forum & Blog. Water is life. Constant pressure system with air venturi iron filter Jun 4, 2015
Pumps and Tanks Well Forum & Blog. Water is life. Well pump runs constantly and pressure tank doesn't fill May 23, 2015
