constant drip
Discussion in 'Toilet Forum discussions' started by ronwtl, Aug 4, 2007.
  1. ronwtl
    ronwtl New Member
    Aug 4, 2007
    I installed a Toto Drake toilet in my house in June. Recently it started dripping constantly from the rubber tube into the overflow tube. The rate of dripping has increased almost daily to a steady drum beat. I have checked the filter on the Type A fill valve and it is clean. That was Toto tech support's only recommendation. What do you recommend, replacement of the fill valve, or something more simple? If replacement, what brand and where to get it?
  2. Terry
    Aug 17, 2004
    I don't know which one is considered type A, but some have used the Korky style fill valve.
    Instructions are here
    If it's the Korky style, the $2.50 assmebly cap can be replaced.
    If it's the type with the screw adjustment, then replacing the fill valve with a Korky is the best solution. Lowes has them on the shelve, for $9.99
    They also carry the G-Max flappers.
Similar Threads: constant drip
Toilet Forum discussions Is it the toilet or the drain/vent causing the constant clogging? Sep 11, 2016
Toilet Forum discussions Toto Neorest 600 water constantly trickles into bowl while in use Aug 1, 2016
Toilet Forum discussions constant running water after new toilet repair kit installed Jun 29, 2014
Toilet Forum discussions toto guinevere running constantly, help! Jan 24, 2011
Toilet Forum discussions constant clogs in two toliets Dec 27, 2010
