Constant drip down drain valve from Culligan Iron-Cleer
Discussion in 'Water Softener Forum, Questions and Answers' started by Pkenn, Dec 26, 2011.
  1. Pkenn
    Pkenn New Member
    Dec 26, 2011
    Virginia
    Hi!
    For the past 8 months, there's been a constant drip down the drain valve from my Culligan Iron-Cleer. They system was installed in 2002. The company that installed the system has sent repairmen out at least six times and their "repairs" do not permanently fix the problem. The sealpack and bell crank were replaced TWICE; an extra large blue filter installed to filter additional silt after silt was found & cleaned off valves & other parts; pointer on iron-cleer clock checked on one visit and then fixed on another.
    At one point, I let the drip go w/out calling for another repair visit. The drip turned into a flow which eventually resulted in a total loss of pressure. For the past 3 months, I've had the system in bypass mode. Recently, the water began to smell...so I turned it back on. Now, the drip is back....
    I'm at a loss because the local Culligan dealer has been unable to diagnose and fix the problem. Any suggestions? Thanks!
  2. Akpsdvan
    Akpsdvan In the Trades
    Dec 29, 2009
    Business owner/service and sales
    Alaska
    What is the size of the micron for the pre filter? it might not be small enough to stop the silt that is getting in the seal pack area and killing the o rings.
    Until that part is fixed so that the silt is not getting into the Culligan head... you will be replacing the seal pack every x number of months or years.
    Also on the pre filter , how big is the filter that is in the housing? 4x10 2x10 or 4x20 or 2x20?
  4. wangtao
    wangtao New Member
    Nov 14, 2011
    China
    Hi,Pkenn,
    Please send your picture on your forum,Maybe picture will help you to fix this problem.
  5. rjh2o
    rjh2o Member
    May 10, 2011
    Michigan
    If there is indeed sediment coming from the well this is a problem. More likely the valve itself needs to be cleaned and media replaced in tank. If sediment got into the media tank it can be stirred up with each backwashing cycle. The "sealpacks" on the system are very susceptible to any sediment, the seals get scored and causes the unit to run to drain. This would explain the temporary fix with new sealpacks and the re-occurence of same problem several months later. These units typically need to be re-bedded every 10 - 12 years depending on water chemistry and usage. I would have them clean the valve internals completely before they install any new parts also.
    RJ
Similar Threads: Constant drip
Water Softener Forum, Questions and Answers Clack Drain line constant drip Nov 10, 2012
Water Softener Forum, Questions and Answers cullingan iron cleer constantly draining Jan 19, 2014
Water Softener Forum, Questions and Answers Flek 7000sxt constant drain Jun 9, 2013
Water Softener Forum, Questions and Answers water constantly draining need help not sure if its pressure tank or softener problem Apr 30, 2013
Water Softener Forum, Questions and Answers Kinetico K-60 is discharging constantly. Mar 18, 2012
