Considering attaching PVC pipe to cast iron drain with epoxy!
Discussion in 'Shower & Bathtub Forum & Blog' started by bruces, Nov 7, 2013.
  1. bruces
    bruces New Member
    Nov 7, 2013
    simi valley, ca
    Hi All,
    I believe my shower drain has a cast iron drain attached to a cast iron pipe . The cast iron drain and pipe appear to be attached together with lead.
    I was thinking, if I can get the cast iron pipe and lead out of the drain, would it work for me to attach a PVC pipe to the cast iron drain with epoxy. Of course I would clean everything really well, roughen the surfaces, etc. I would add plenty of fillers to make the epoxy not run. West System makes all kinds of epoxies and fillers, I like their stuff. Do you think that will work and what problems do you think I might have? Will it meet code? Is there a better or easier way of doing this?
  2. johnfrwhipple
    johnfrwhipple BATHROOM DESIGN & BUILD for both Canada & the US
    Jul 20, 2009
    Design Work World Wide: Bathrooms Vancouver Area
    North Vancouver, BC
    [​IMG]
    A no hub fitting designed to connect cast to ABS, Copper or PVC is a better approach. You can cut the old cast line with snap cutters, a grinder or a sawsall blade.
    Looks like you will need to bust more concrete to get any tools on that old pipe.
    Might be to tight for most rental pipe cutters. I've seen some small chain snap cutters (shown below). Something like this;
    [​IMG]
  4. Smooky
    Smooky Well-Known Member
    Apr 4, 2011
    North Carolina
  5. johnfrwhipple
    Jul 20, 2009
    North Vancouver, BC
  6. hj
    Any half way decent plumber knows how to remove the lead from a joint, but I would replace it with another cast iron drain so I would not have to make a "Mickey Mouse" connection, although, since this is on a slab floor, no one would ever know if it started leaking. That "buried" PVC cleanout tee would be "handyman type work" if that is the main line out of the house.
  7. jadnashua
    Once you've made some swiss cheese out of the lead with a drill bit, the whole thing will pry out since there's someplace for it to compress a bit while prying (if you have a long enough pipe, you can use it as a lever to get things loose). Then, a wire brush will clean up the CI so you can get the donut in there without leaking - sometimes, some dish soap helps things along. If you get the right size, it's a solid connection. They make them in LOTS of different OD's to accommodate the various hub sizes - there is NO standard on hub sizes, only the ID of the pipe, thus the reason they make the donuts in multiple versions (not counting the ID for the pipe in question). Or, cut off the hub and use a no-hub connection to convert, but keep in mind, sometimes they have the size and brand cast into the outer wall of the pipe, and those humps may make it impossible to seal unless you grind them off. Modern nohub CI doesn't have that - the OD is smooth.
    There are some approved non-lead methods to emulate a leaded connection, but I do not think any of them are epoxy based. Last one I did, I bought a tube of the stuff, then found out it was several years out of date, and no way you could even think of making a seal with it...sort of gives you an idea of how often people use that method (almost never!). Only one place in town had any (Rochester, NY isn't the smallest city, either). I ended up cutting it out and using banded couplings and pvc. It was up against the ceiling of an old plaster and lath construction, and I didn't have the tools or skill to try to make that tricky connection on the horizontal. There wasn't much room between the joists, either.
  8. dj2
    dj2 Member
    Aug 13, 2013
    Winnetka, California
    For a long lasting solution, replace with a new cast iron pipe, as HJ recommended.
    Plumbing solutions that have been working for decades are still better than "new ideas".
Similar Threads: Considering attaching
Shower & Bathtub Forum & Blog Considering Nov 4, 2006
Shower & Bathtub Forum & Blog trouble attaching the new escutcheon Aug 8, 2009
Shower & Bathtub Forum & Blog attaching tile to fiberglass shower base Aug 7, 2007
Shower & Bathtub Forum & Blog Attaching steel tub to wall Oct 16, 2006
Shower & Bathtub Forum & Blog Attaching shower heads to glass block? Jun 22, 2005
