Connection question
Discussion in 'Plumbing Forum, Professional & DIY Advice' started by fatdaddy, Sep 30, 2008.
  1. fatdaddy
    fatdaddy Member
    Aug 14, 2007
    I am removing my sink drain assembly and all went well until the last bit,
    where the drain goes into the wall. The line looks like it goes into a brass piece that has threads on the outside and screws into a galvanized elbow.
    It does not budge!! As you can see,I am losing anything to bite into,so I have stopped and will ask here.Thanks in advance.
    Alan
  2. fatdaddy
    fatdaddy Member
    Aug 14, 2007
    Connection problem--second request!
    :rolleyes:
    Just hanging around for some free advice.Not being pushy.
  4. Terry
    Aug 17, 2004
    Did they solder that in?
    Try scratching it to see.
    If it's soldered, you may need to reheat it.
    It's supposed to be installed with either a brass ferrel sleeve, or a rubber slip joint washer.
  5. nhmaster
    nhmaster Master Plumber
    Jul 30, 2008
    Tech. Instructor
    S. Maine
    Sure looks soldered to me. Someone run out of washers?
  6. fatdaddy
    fatdaddy Member
    Aug 14, 2007
    It was soldered into the threaded brass piece that
    was then screwed into the threaded (female) fitting. It looks like a galvanized fitting with lead-wiped pipe connection. I tried heat but chickend out--not wanting to burn the house down.
    I used a chisel to remove the existing connections and have purchased a galvanized nipple and pvc trap.
    Wish me luck!
  7. hj
    brass
    It is a solder bushing adapter. You have to remove the tubular piece, then cut the brass piece out of the fitting, then install a new adapter.
Similar Threads: Connection question
Plumbing Forum, Professional & DIY Advice Installing new faucet, connection question Sep 20, 2015
Plumbing Forum, Professional & DIY Advice Wet venting options and a toilet connection question May 15, 2015
Plumbing Forum, Professional & DIY Advice 3" drain connection questions Aug 4, 2014
Plumbing Forum, Professional & DIY Advice Push-Fit Connections and Deburring - a minor but important question Jul 2, 2014
Plumbing Forum, Professional & DIY Advice PEX connection question May 25, 2014
